A/C clutch not cycling - JeepForum.com
post #1 of 9 Old 05-15-2013, 07:12 AM Thread Starter
Heathc
1997 XJ Cherokee
hey everyone, my A/C clutch isn't cycling on my 2001 Cherokee Sport. i've replaced the relay already. i'm trying to go through the simple stuff first. is there a fuse for the A/C in the kick panel fuse block? if so, can anyone tell me which one it is? i couldn't find it anywhere in the shop manual. also, any idea as to what may be causing the problem?
thanks!
Heathc is offline
post #2 of 9 Old 05-15-2013, 07:55 AM
bht911sc
Is there refrigerant in the system? There is a pressure switch that has to be bypassed to engage the compressor.
bht911sc is offline
post #3 of 9 Old 05-15-2013, 08:18 PM Thread Starter
Heathc
1997 XJ Cherokee
it was working fine, but the clutch stopped kicking in.
Heathc is offline
post #4 of 9 Old 05-15-2013, 08:19 PM Thread Starter
Heathc
1997 XJ Cherokee
also, shouldn't the compressor clutch kick in when the defroster is on?
Heathc is offline
post #5 of 9 Old 05-15-2013, 10:31 PM
bht911sc
Yes, I would start with a test light or volt meter and work back from the a/c clutch.
bht911sc is offline
post #6 of 9 Old 05-16-2013, 05:43 AM Thread Starter
Heathc
1997 XJ Cherokee
can someone tell me the location of the fuse for the A/C clucth, if there is one. i assume the system has to have a fuse somewhere. i know where the fuse block is in the kick panel, but i don't know exactly which fuse it is. my shop manual doesn't tell me.
Heathc is offline
post #7 of 9 Old 05-17-2013, 07:21 AM
bht911sc
If you look real close, there are embossed words next to or above the fuse..at least they are on my 91.
bht911sc is offline
post #8 of 9 Old 05-17-2013, 01:12 PM
djb383
Have u looked in the fuse box (PDC) under the hood passenger side?
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #9 of 9 Old 05-17-2013, 02:11 PM Thread Starter
Heathc
1997 XJ Cherokee
not at those fuses, but i did replace that relay. i'll look there.
Heathc is offline
