A/C Clutch doesn't engage - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > A/C Clutch doesn't engage
TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-16-2013, 03:47 PM   #1
Ken89YJ
So my a/c clutch doesn't engage when I turn my a/c on. I checked the fuses, replaced the relay, jumpered the low pressure switch, and tried just filling the refrigerant to build pressure to get the clutch to turn on. I'm kinda stuck with what to try next or to look for so any help would be greatly appreciated. The jeep is a 1998 Cherokee 4.0 5 speed.
Ken89YJ is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 09:22 PM   #2
AZ Jeff
2014 JK Wrangler
Do you have 12V to the clutch when the pressure switch is jumpered? If so, then you have a clutch issue. Check the air gap and adjust as needed. If that fails, replace the clutch (or compressor).
More details can be found here: http://www.sanden.com/originals/imag...uide_Rev.2.pdf
AZ-Jeff
1992 XJ -- stock (RIP)
2000 XJ -- lots of basic mods. Sold to fellow forum member. I miss it.
2014 JK -- the project is just starting!
AZ Jeff is offline   Reply With Quote Quick reply to this message
