C clips on an 8.25 - JeepForum.com
post #1 of 3 Old 12-27-2008, 06:36 PM Thread Starter
Rollin
C clips on an 8.25
Is it possible that the c-clips on the shafts of my 8.25 have been worn to the point where the shaft is no longer tight against the pin in the center? I get a 16th of an inch movement in and out which makes for an annoying sound when I go over bumps.
I thought the tire was not torqued down properly but i guess not cuz all of the lugs are tight . I can kick the tire with it on the ground and it makes the exact sound that I hear in the cab. The sound is the same sound as when you put the tire back on the hub after taking it off.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #2 of 3 Old 12-27-2008, 08:13 PM Thread Starter
Rollin
Maybe what I should ask is if there is a thicker c clip that I could use to tighten up the shafts?
Rollin is offline
post #3 of 3 Old 12-27-2008, 11:34 PM
urbex
There's always going to be movement in the shafts. If you tighten it up to the point of no movement, the shaft is going to be bottomed out against the cross pin in the differential, and will wear away at either the pin, the end of the axle shaft, or both, eventually causing slop again. Not to mention, you're potentially weakening the cross pin and/or shaft in the process of doing that. There's something else loose back there causing that sound.
urbex is offline
c-clips cherokeewes XJ Cherokee Technical Forum 3 05-10-2008 09:26 AM
where to get c-clips? shmoken875 XJ Cherokee Technical Forum 10 04-01-2007 07:10 PM
sound clips josiah3205 XJ Cherokee Technical Forum 1 02-19-2007 07:45 PM
Exhaust Clips SlimGoaty XJ Cherokee Technical Forum 17 05-09-2006 10:40 PM
So, do i have C clips??? Jeffro600 XJ Cherokee Technical Forum 4 09-15-2005 02:49 AM
