I have a 90 Cherokee limited, no heat. Wanna bypass heater control valve for heat throughout winter, would this method work after flushing the heater core for temporary heat to keep the kids warm? Also.... would I be able to cut off the valve to reconnect steel line to the rubber hose instead of buying hose to do a direct bypass? If I do this and the motor continued to heat up past 210, what other problems could be cause of over heating? Also wondering if all vents would work as normal if the vacuum line remains attached to the valve after being cut from the coolant line, or if plugging the line would be effective as well... thanks for reading
Redundancy. Over-engineering. Just put a tube in it's place. Plug the vacuum line to the valve that is now gone. I live in Arizona and have no HCVs on my three Jeeps.
Have you determined that there is an actual problem with the valve? Is it stuck closed?
And are you also having a problem with the engine over heating? (Silly question, it's a Jeep after all...)
Maybe both issues are being caused by an air pocket in the system??
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
