Quantcast Buying Cherokee - what to look for? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Buying Cherokee - what to look for?
Old 12-03-2003, 01:09 PM   #1
Scott atah
Hey there ladies n gentlement. I'm wanting to get rid of my car ('90 ford thunderbird supercoupe) as i believe it's on a downward spiral yet again and i'm not up for fixing it yet again.
So i'm lookin into different vehicle...and i'm thinkin i could handle a jeep. Only problem is i don't know a whole lot about them and i don't have a ton of time to hang around the board and just read bout what issues and stuff they have. So i'm hoping you can give me some quick hints as maybe what to look for on a used Jeep.
Lookin around the 1991 (under $4000 cdn) most of which have 200,000+ kms. Is there any known issues with the jeeps that i should check for? I know my car head gaskets at about 160km and tranny a lil after (both of which i had to do lol); anything similar with the jeeps?
But yeah just in general some pointers of what to look for or what to stay away from...or a heads up on anything you can think of.
Scott atah is offline   Reply With Quote
Old 12-03-2003, 05:28 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
In general, go 92+. Sounds like you're on a budget, so I'd say look for a 92-95. These units have the High pinion D30 axles, Non-vacuum disconnect engagement, better cooling systems, and better wiring (than the 90 below).
Do a serch for pics of the Chysler 8.25 rear ends and make sure that is the rear end you get. You don't want the D35 unless you have to have ABS. I know I'm forgetting some things, but I'm sure the others will add some stuff. Hope you find a good one.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 12-03-2003, 08:04 PM   #3
Islandroaddie96
Definately get the 4.0L engine. You'll be glad you did. And, obviously, get one with 4wd. If you drive a lot in winter type weather, (snow, ice etc.) you can find one with the Selec-Trac transfer case (NP242) which will give you a Full-Time option. Other than that, all XJ's between 92 - 95 were basically built the same. 96's are slightly different and '97 and up are the ones with the "new body style".
Good Luck and Welcome to the world of Jeeps (hopefully),
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline   Reply With Quote
Old 12-03-2003, 09:27 PM   #4
Maybe
If you going to wheel it you will want to go with the 4.0 and a automatic tranny. Going with the NP-242 is always a good idea also. The way to tell if its a NP-242 the transfer case shifter inside will read--- 2wd, part time 4wd, full time 4wd, 4wd low...
Easy to lift and wheel really good.
Check out ebay there are a bunch on there fairly cheap if you wanna drive alittle.
90' XJ 4.0, Auto, np242 t-case, RE 3.5" lift, D44 rear, (locked)
2 1/4" tube from the header to the muffler.
Maybe is offline   Reply With Quote
Old 12-03-2003, 11:52 PM   #5
CLASH
I am going to be buying my own XJ soon and want a 8.25 in my XJ does anybody have a good pic of one they could post please?
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline   Reply With Quote
Old 12-04-2003, 12:04 AM   #6
thephantum
1997 XJ Cherokee
This should give you somewhat of an idea...http://www.quadratec.com/cgi-bin/sgdynamo.exe?HTNAME=jeep/differentials/pic.html
I'll see if I can find an actual photo and post it here as well.
Rock On!
Steve
[CENTER][SIZE=3][URL=http://www.fm2cd.com][COLOR=darkred]Follow Me To Certain Death 4x4 Club VA Chapter Founder[/COLOR]
[/URL][/SIZE]
[size=3][url=http://jeephorizons.com][COLOR=sienna][b]Jeep Horizons - Where Avatars are always free[/COLOR][/b][/url][/size]
[B][size=3][url=http://www.links4jeeps.com/in.php?id=893/]Links 4 Jeeps - Yup, they're free here too[/url][/size][/B]
[URL=http://www.fm2cd.com/chapters/VA_Chapter/VA_Members.htm#cname]
97 XJ Sport 2 door with a bunch of stuff[/URL]
[url=http://www.fm2cd.com/chapters/VA%20Chapter/VA%20Members.htm#dname]
02 TJ Sport with a bunch of stuff[/url][/center]
thephantum is offline   Reply With Quote
Old 12-04-2003, 12:33 AM   #7
Scott atah
alrighty yeah...i'd like to get a 4.0 HO...i'm definitely on a budget as i just got outta school and already have an $18,000 debt to work with....and yes winter conditions in edmonton, alberta canada, can get pretty hurrendous!
4x4 is a necessity...i'll keep in mind the other things you've mentioned.
Are there any things that pretty well break around the 200k km mark on all jeeps? Or nothing really?
Old 12-04-2003, 12:36 AM   #8
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Water pump, maybe fuel pump.
93 Sport
Specs in Profile.
Old 12-04-2003, 01:00 AM   #9
Islandroaddie96
Also, the computer sensors on these things (particularly the CPS and TPS) are prone to failure after awhile. They can cause the truck to run erratically or in extreme cases, not at all. Not a big deal though. . . They are easy to change out and are not very expensive. Other than that, just normal wear and other things that you'd expect on a car of this age would need.
Good Luck,
Peter
1996 XJ Sport
Old 12-04-2003, 11:34 PM   #10
tekeum
I just bought my first XJ this week. I got A 94 sport with140,000 for $2,400 on ebay. mabey you should try ebay? This left me with about $6,000 to do some mods.
tekeum is offline   Reply With Quote
Old 12-05-2003, 12:36 AM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
My wife is gonna kill me, but I noticed a 91-95 XJ at the local auction place down the street from my house. Still haven't gotten a good look at the front, I may be a 3 XJ household soon!!!!!!!
I bought my 93 Sport with 108XXX on the odo for $3500 (with TTL).
93 Sport
Specs in Profile.
Old 12-06-2003, 01:22 PM   #12
Sykes
Fuel Pump Noise
At 197.000 miles, replaced water-pump, power-steering, and timing-chain. The water-pump
started sounding like gravel with bearing squeal
and finally dumped anti-freeze through blown bearing.
The fuel-pump hums in the back tank like
a loud aquarium air-pump from the 70's. Is this
normal? People point it out like its an air-leak.
Also, is a delayed start with about a 10-sec lag
normal? Seems like this would put stress on the
starter, which I also repalced (looked like
the original).
Desert Rat Cherokee Laredo
'87 4.0L 6Cyl AT.
Sykes is offline   Reply With Quote
Old 12-07-2003, 09:38 PM   #13
Islandroaddie96
The fuel pump is definately audible, however without hearing it in person, it's hard to determine if it's "too loud". If you have a long cranking period, it may actually be related to the fuel pump not pressurizing the system well. If that's not it, check your CPS.
Good Luck,
Peter
1996 XJ Sport
Old 12-07-2003, 11:10 PM   #14
cadmobile500
also, if buying one with a manual trans, make sure it will downshift smoothly while coasting. if not you will need syncro's and thats big bucks!!!
make sure the heat works. heater cores clog on these things and are a real pita to replace.
i paid $100 for my wifes 90' larado(230k, automatic trans) and put a $52 tie rod in and a $155 windsheild. we still need to have the heater core replaced wich is going to cost us $240 since we already bought the h/c for $29.
paid $450 for my 92 sport(174k, bad manual trans, 5-1/2" lift, tubular lca's) and just put a $40 battery.
both vehicals were bought at an auction with no warenty, but for a cheap *** like myself with some mechanical skills we couls spend more on repairs and still be ahead. these are just our winter beaters, though we are growing to love our jeeps.---tom
CURRENT;
92 cherokee larado 4.0l
DESEASED;
92 cherokee sport; 5-1/2"? syjacker lift, 31"(lost 1st and 2nd gear)
90 larado 4.0l(snaped timming chain)
91 limited 4.0l($1000 brake part???)
cadmobile500 is offline   Reply With Quote
Old 12-10-2003, 04:12 PM   #15
jeepcherokee
Stay away from a 1991 with the Bendix ABS-10 system: it is prone to cause you trouble (speaking from my own experience).
Furthermore, check if all recalls have been done (if applicable) by entering the VIN-code on the Chrysler website. Or, alternatively, call Chrysler and they should be able to tell you.
jeepcherokee is offline   Reply With Quote
Glock Forum
