Burnt Transmission Fluid, help? - Page 2 - JeepForum.com
post #16 of 24 Old 09-07-2013, 08:50 AM
psychoteen101
Does running that fluid depend on the year of the jeep? Ive been running ATF+4 in my 96 because thats what it suggests to use.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #17 of 24 Old 09-07-2013, 11:07 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Dexron/Mercon transmission fluid is the specified AW-4 fluid in both the Cherokee Owners Manual and the Cherokee Factory Service Manual.
CJ7-Tim is offline
post #18 of 24 Old 09-07-2013, 11:47 AM
CCKen
CCKen's Avatar
I went through several documents dating back to c. 1987/1988 and gathered up the AW4 transmission fluid recommendations over the years. Here's the data. Note that there is no mention of ATF+3 or +4 in this data. Note also that in '93 Mercon was the ATF recommended, with no mention of Dexron (odd).
ATSG AW4 Service Information Manual, c. 1987/88
Recommended fluid for the AW4 transmission is Jeep or Mopar Mercon automatic transmission fluid. Mopar Dexron II may also be used if Mercon is not available.
1988 Jeep Cherokee FSM
Both transmissions and transfer cases use DEXRON-II ATF.
1989 – 1992 (unknown FSM recommendations)
1993 Jeep Cherokee FSM
Aisin Warner AW-4 transmissions and transfer cases use Mercon type ATF.
1994 - 1999 Jeep Cherokee FSM
Recommended and preferred fluid for the AW–4 transmission is Mopar Dexron IIE / Mercon.
Mopar Dexron II may/can be used but only in emergency situations where Mercon fluid is not available.
Approximate refill capacity for the AW–4 is 8.0 liters (16.9 pints).
2000 Jeep Cherokee FSM
Mopart Dexron IIE / Mercon is the recommended fluid for the AW-4 automatic transmissions. Mopar Dexron II can be used but only if Mercon is not available.
2001 Jeep Cherokee FSM
Mopart Dexron III / Mercon is the recommended fluid for the AW-4 automatic transmissions.
Dexron II fluid IS NOT recommended. Clutch chatter can result from the use of improper fluid.
CCKen is offline
post #19 of 24 Old 09-07-2013, 03:28 PM
psychoteen101
See TSB 21-010-06 4/14/2006
Mopar (R) ATF Plus 4, Type 9602 automatic transmission fluid is the recommended fluid type.
This is what i get from alldata on a 96. Id consult my owners manual, but thats long gone.
post #20 of 24 Old 09-07-2013, 06:09 PM
CCKen
CCKen's Avatar
psycho,
The OP was just asking about what to do with his 'burnt' ATF. And posters with a collective 29,000 + posts under their belts gave their recommendations. Additionally, they recommend using Dex III/Mercon - just what the FSM recommends for the AW4, and nothing else.
If you want to use ATF+4, have at it.
CCKen is offline
post #21 of 24 Old 09-10-2013, 01:51 PM
psychoteen101
Im just trying to get the correct information. I felt Alldata was a pretty reliable source. No offense to you or anyone else, but post count is not a factor of knowledge to me. I suppose I can always call and confirm with a dealership as to whats the correct fluid to use. Not arguing the fact that the OP's 98 Cherokee is recommended to use dex/merc, but info I can find on a 96 says ATF+4
post #22 of 24 Old 09-10-2013, 03:16 PM
CCKen
CCKen's Avatar
Sorry about the post count comment. Perhaps it would be more clear to say that the referenced poster's credentials go beyond their post counts on this forum but more so on the years of experience they have.
There have been countless threads on every Jeep forum about ATF for the AW4, going back and forth about ATF+4 vs. Dex/Merc. If you didn't hijack this thread and searched the subject out you could have learned a bunch about ATF choices.
Like I said earlier, do what you want. If ATF+4 seems right for you - do it.
If you call the dealership they will tell you ATF+4 because that's what the current TSB states.
CCKen is offline
post #23 of 24 Old 09-10-2013, 03:36 PM
dmill89
1995 XJ Cherokee
Page 12 of the AW4 service manual (see link) clearly recommends Mercon (Dexron III) or Dexron II if Mercon is not avalible:
http://www.pirate4x4.com/tech/billav...AW4_manual.PDF
So does Page 220 of the XJ owners manual:
http://www.jeep4x4center.com/knowled...?utm_source=cj
If you call the dealer they will probably tell you ATF+4 per the 2006 TSB, but the AW4 is NOT a Chrysler transmission and this was only done to reduce the inventory costs of carrying a different fluid. Aisin has never recommended anything other than Mercon/Dexron(II or III depending on year).
ATF+4 may work in an AW4, especially if it is new, recently rebuilt, or has very little wear, however ATF+4 is much thinner than Dexron III/Mercon and is known to cause a significant drop in line pressure which can cause slipping or poor shifts, especially in a worn transmission.
Dexron III/Mercon is also much cheaper and easier to find than ATF+4, so why spend more money on a fluid that might cause problems and isn't recommended by the manufacture of the transmission?
dmill89 is offline
post #24 of 24 Old 09-10-2013, 04:13 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Well said. Completely agree with this assessment.
Some with the AW4 can use ATF+4 with no issues. But some experience "slippage". There are never any issues with Dex/Merc and it will give your transmission a very long service life if the fluid is changed regularly.
Dex/Merc for me and any AW4 transmissions that I service. Why take the chance?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
cherokee , maintenance , transmission , transmission fluid
