Burnt Fluid in Transmission, what do i do? - JeepForum.com
post #1 of 3 Old 09-06-2013, 09:24 AM Thread Starter
YeOlCherokee
I have posted a thread about this a while back, and i am getting ready to do the deed, but i just wanted to talk to you guys quickly about some thoughts I've had.
Just as a recap of info: I have a 98 Cherokee 4.0 with the AW4 with approximately 130,000 miles on it. This vehicle is 100% stock and has never towed anything.
My fluid it burnt. Its completely brown on the dipstick and definitely smells burnt. The fluid is at the correct level, and the transmission operates FINE (from what i can tell)
Most of you guys told me to do the drain and fill method, just draining the pan, refilling those 4 quarts, and repeating every few hundred miles until it stays red
My concern is that while, obviously the transmission will fail at SOME point if i leave the burnt fluid in there, i'm afraid that the cleaning agents in the new fluid will clean out all the "crap" in the old fluid that the transmission got used to running on (by driving so long with burnt fluid etc.)
So with that in mind, do you guys advise doing the drain fill method still or just leave it in ? I know its like rolling the dice with this situation, but i am just trying to make the best decision here. Obviously maintaining a vehicle properly from the start is the right thing to do, but unfortunately i am stuck buying used vehicles.
Anyway, as a last note, what should i do? and what about the filter? should i wait to change it until i do a few cycles of the drain and fill ? And would you guys advise adding a bottle of Lubegard Red to the mix to help condition stuff (i dont know what it does, im a sucker, just heard some good things about it)
Also i bought 12 pack of DexIII/ Merc by Peak, any input on that?
YeOlCherokee is offline
post #2 of 3 Old 09-06-2013, 10:14 AM
Speedymcracer01
I definitely do not recommend putting additives in the trannsmission the only thing you can really do is drop your pan drain fluid clean the pan and magnet remove old filter most people just replace the filter put it back together and poor the fluid in..but i would recommend adjusting the bands to the specs in the repair manual,which you will need a torgue wrench to do
Speedymcracer01 is offline
post #3 of 3 Old 09-06-2013, 11:09 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Drain, re-fill, repeat. No additives needed. If it says Dexron-III/Mercon it wiil work.
CJ7-Tim is offline
cherokee , fluid recommendation , maintenance , transmission fluid , transmission issue
