Burning up starter - JeepForum.com
post #1 of 9 Old 09-19-2012, 08:39 AM Thread Starter
Ohenry34
Burning up starter
I am having an electrical issue and I really need some help. '99 Cherokee with 4.0 straight 6. I have burnt up 3 starters in a matter of about a week. First voltage gauge dropped dash and headlights went dim for few seconds then everything returned to normal. Smelled electrical burning and parked, starter was completely dead when I investigated. I put new altenator on (assuming it was diode and alt was weak anyway). Fixed that problem (sorta) but when I parked the other day I turned Jeep off and starter was still spinning. Now starter is completely dead again. Do not know if starter was spinning will running because i didn't hear grinding or anything. Also ignition had lag of bout .5-1 sec between key turn and starter engage. Any help or direction would be greatly appreciated.
Thanks
Ohenry34 is offline
post #2 of 9 Old 09-19-2012, 07:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Where did you buy the starter ? Tested or replaced the starter relay ? Any troubles with the ignition cylinder ?
CJ7-Tim is offline
post #3 of 9 Old 09-19-2012, 08:48 PM Thread Starter
Ohenry34
I bought the starter from OReiley's. It is a reman (Mitsu i think). Have not tested the starter relay. How do i do so? As far as ignition, there is some lag between key turn and starter engage. I was thinking maybe ignition switch could be an area to address.
Ohenry34 is offline
post #4 of 9 Old 09-20-2012, 07:17 PM
CJ7-Tim
CJ7-Tim's Avatar
Sounds like a sloppy rebuild. Do yourself a favor and buy a good quality rebuilt starter or even a new starter. Cheap crappy "Lifetime Warranty" parts are often out of specification or even failed right out of the box. Many times they have a short service life before they fail. Buy good quality replacement parts and genuine Jeep sensors.
CJ7-Tim is offline
post #5 of 9 Old 09-20-2012, 07:57 PM
Carl48
Sounds as if the starter is staying engaged when the key switch is returned to the "run" position. This will destroy the starter in short order. There should be no voltage present on the small terminal on the starter solenoid when the key is returned to the "run" position.
Carl48 is offline
post #6 of 9 Old 09-20-2012, 08:55 PM Thread Starter
Ohenry34
i unfortunately didn't ask when i bought the starter just told them what i need and bought the one the guy gave me. I agree though i think that i will see if i can warranty and get credit on actual new starter
Carl,
gonna check that out tomorrow after work cause i have the same suspicion. but when burnt up last one ignition was actually switched off and starter was still spinning. I dont know how the excite wire would get voltage with key off, unless there was internal short between B+ and excite wire in the starter. what do you guys think?
Ohenry34 is offline
post #7 of 9 Old 09-20-2012, 09:10 PM
no5son1962
I had a similar problem with my ZJ 4.0. Strange intermittent electrical problems to include the starter not shutting off. After much trouble shooting to include ignition switch replacement I found the ground wire from the battery to the fender was fried. I replaced the wire with a heavy cable and haven't had a problem since.
95 ZJ 4.0L 3 inch Lift
99 XJ 4.0L 4 inch Lift
no5son1962 is offline
post #8 of 9 Old 09-21-2012, 03:47 AM
Carl48
If the contacts in the starter relay (in the fuse box under the hood) were welded closed, the condition you describe would exist.
Carl48 is offline
post #9 of 9 Old 09-23-2012, 09:03 PM Thread Starter
Ohenry34
Well I replaced starter relay and got the starter warrantied. Lag between ignition and starter gone now so I think that is a good sign. On a side note O'Reilley's does even offer a brand new starter, reman is only thing available. Guess I might be going somewhere else for parts from now on...I will update soon but hopefully I got the problem solved. Appreciate the input from everyone.
Ohenry34 is offline
electrical , ignition , starter
Starter Issues..new starter... ground issue maybe..?? Camfam07 XJ Cherokee Technical Forum 5 06-03-2012 11:25 AM
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 03:45 PM
Burning Oil... 96xjmyjoy XJ Cherokee Technical Forum 13 03-11-2011 05:44 AM
Burning serious oil???? help AuburnXJ XJ Cherokee Technical Forum 8 02-14-2009 06:43 PM
burning brakes of burning clutch? master999 XJ Cherokee Technical Forum 3 01-19-2008 12:50 PM
