Quantcast Burning up fuses!?!?!?!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Burning up fuses!?!?!?!?
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 05-17-2008, 07:21 AM   #1
LCFRJEEP
1997 XJ Cherokee
Hey guys,
Gotta 95 XJ and I have been recently going through fuses on the panel under the dash and the one under th hood. The fuses that keep blowin' are the fuse that controls the pwr windows, pwr door locks, radio and the interior lights. All of those amenities are consolidated on one fuse under the dash on the drivers side. As for the panel under the hood on the passenger side of my rig, it is the mini-fuse that controls the interior lights, radio and anything that is powered when you just have the ignition on. Any suggestions???
LCFRJEEP is offline   Reply With Quote
Old 05-17-2008, 04:19 PM   #2
madrabbitt
A fuse blows because of an abnormal amount of amperage going thru the fused circut, usually because of a short.
If your fuse keeps blowing, that means you still have a short.
Find the problem, fix it, THEN replace the fuse.
Dont just keep slapping fuses in there.
Unless you want to make your XJ into a BBQ.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 05-17-2008, 05:21 PM   #3
LCFRJEEP
1997 XJ Cherokee
10-4 there good buddy
Old 05-17-2008, 05:22 PM   #4
kencaz
Originally Posted by LCFRJEEP View Post
Hey guys,
I am assuming that the fuses are not blowing immediatally, or you would not bother continually replacing them. So it's probably safe to assume that it's not a short to ground.
I could be many things such as a loose connection or something is failing. I would first look at the door and window systems. It could be that a door lock accuator or a power window motor switch is sticking causing either the accuator or the motor to heat up and blow the fuses.
Try replacing only the under hood fuse first. If it does not blow then more then likely the problem can be traced from the output of the under dash fuse. Try all the swithes for the windows and doors as well as the headlamp swith and dimmer.
You could also check for continuity to ground from the output of the dash fuse.
CAUTION: Continuity is done with no power so FIRST use a test light to determine which side of the fuse is the input. That will read 12V, and the light will light up. The other side should read 0 volts with the fuse removed. Then you can perform the contiuity check to ground on the ouput side.
Good Luck
KC
My Cherokee
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline   Reply With Quote
Old 05-17-2008, 05:24 PM   #5
ebel_04
1990 XJ Cherokee
ive been having the problem with my jeep.. a couple weeks ago it caught fire a little bit thought... still cant find the problem and ive been through all the wiring under the dash.. its a mess
ebel_04 is offline   Reply With Quote
Glock Forum
