Burning serious oil???? help - JeepForum.com
post #1 of 9 Old 02-14-2009, 10:26 AM Thread Starter
AuburnXJ
1993 XJ Cherokee
i have a 93 XJ (4.0) w/ 170k+ on the dial, and my jeep is burning oil pretty good. any ideas about what the problem could be?
2001 Jeep Cherokee Limited - DD
4.5" Rusty's SA Kit-32x11.5 BFG AT-Super 44 w/ turndown-JKS Discos
1993 Jeep Cherokee - Trail Rig
6.5" Rusty's LA kit-33x12.5 TSL-Pacesetter Header w/Delta 40-JKS Discos-Tom Woods Driveshaft-Advanced Adapters SYE-Custom CAI
Coming This Summer: 44/9", 4 link rear, and 37s
AuburnXJ is offline
post #2 of 9 Old 02-14-2009, 10:32 AM
Kenbo-Slice
Bad piston rings maybe.... When was the last oil change, who did it, and how thin was the oil. Oil that is too thin (especially on a higher milage vehicle) will be prone to burning up quick. You may just be able to use thicker oil. I would get more oppinions though... I melt metal together for work, I'm no mechanic.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #3 of 9 Old 02-14-2009, 10:43 AM Thread Starter
AuburnXJ
1993 XJ Cherokee
its 10W 30... and it has been a while since the oil got changed
AuburnXJ is offline
post #4 of 9 Old 02-14-2009, 10:52 AM
Kenbo-Slice
like I said, I'm not a mechanic but I would try changing it, and running maybe a 20W 30. That may do the trick.
post #5 of 9 Old 02-14-2009, 11:06 AM Thread Starter
AuburnXJ
1993 XJ Cherokee
ok cool. thanks man
AuburnXJ is offline
post #6 of 9 Old 02-14-2009, 11:07 AM
Kenbo-Slice
No problem.
post #7 of 9 Old 02-14-2009, 11:07 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
x2 on the thicker oil. I'm burning 5w30 like crazy bc i need to run it in the winter (lots of short trips to class in the morning). 15w40 diesel will be going back in in a month for the warmer weather. I barely burned that thicker stuff.
Factory Four Link
XJLI is offline
post #8 of 9 Old 02-14-2009, 02:03 PM
CheapJeep88
Hey I have kinda the same question about oil. I just recently changed my oil in my 88 cherokee with 186k and now all the sudden my valves will tap and its really bugging me. It never did it until I changed it.. So do you guys recommend running thicker oil in and if so what is my best bet..
Thanks!
CheapJeep88 is offline
post #9 of 9 Old 02-14-2009, 05:43 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
It might be a good idea to find a good compression gauge and run a compression test to give you more information about the mechanical condition (rings, etc).
Keep fresh oil in it; old oil has a tendency to burn up a bit quicker in high mileage engines.
Do you have any evidence of oil in your air cleaner box? If you do, search for BLOWBY.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
help 94 4.0 ho burning oil jpuckett12 XJ Cherokee Technical Forum 9 10-09-2008 11:13 AM
Burning Oil?? Sciotojeeper XJ Cherokee Technical Forum 1 03-26-2008 11:48 AM
burning brakes of burning clutch? master999 XJ Cherokee Technical Forum 3 01-19-2008 11:50 AM
Burning more oil? RamboPants XJ Cherokee Technical Forum 8 01-01-2008 05:25 PM
burning cat... 95XJMIKE XJ Cherokee Technical Forum 5 09-07-2007 04:26 PM
