Burning Oil... - JeepForum.com
post #1 of 14 Old 03-08-2011, 04:12 PM Thread Starter
96xjmyjoy
Burning Oil...
Next problem to fix... Noticed that my white garage door had black splatter on it. (I back the XJ up) So I was thinking that maybe since this jeep has no o2/cat on it that would be it. However, when I pulled the cap off the Valve cover it was smoking slightly. This engine doesn't leak anywhere at least...
So am I burning oil for sure? Only way I will be able to tell for sure is after another oil change and a Cat gets put on...
Til then, a link to a good stroker writeup please!
96xjmyjoy is offline
post #2 of 14 Old 03-08-2011, 04:27 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
both those things are normal at startup when the engine is running in open loop. It will run very rich (thus the black on the door). It's also normal for the hole for the valve cover to "smoke" with the cap off when the engine is hot, only it's not smoke it's steam.
You would be getting blue smoke behind you if it were burning oil. 4.0L's are not known for being oil burners (just leakers )
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #3 of 14 Old 03-08-2011, 04:42 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
[QUOTE=96xjmyjoy;11119886]So am I burning oil for sure? /QUOTE]
Are you using "measurable" oil as shown on the dipstick?? And if so, how much?
That will tell the story if you are burning oil.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 14 Old 03-08-2011, 05:59 PM Thread Starter
96xjmyjoy
Will wait and see. Just got an oil change so I will monitor all my symptoms.
post #5 of 14 Old 03-09-2011, 03:33 PM Thread Starter
96xjmyjoy
In another thread I think I have decided to check my MAT sensor along with replacing the o2 sensor before I diagnose it as burning oil. Will monitor it all though.
post #6 of 14 Old 03-09-2011, 05:16 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
you don't have a MAT. You have a MAP though...
dukie564 is offline
post #7 of 14 Old 03-09-2011, 07:31 PM Thread Starter
96xjmyjoy
And is the MAP located at the front of the manifold?
post #8 of 14 Old 03-09-2011, 07:56 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
no it's above the back of the valve cover. Has a wiring harness and vacuum tubing running to it.
dukie564 is offline
post #9 of 14 Old 03-09-2011, 11:39 PM Thread Starter
96xjmyjoy
Dukie-
If you look here http://www.jeepforum.com/forum/f11/e...es-go-1178627/
This is what I am trying to figure out. Will try to figure this out before I pursue thew burning oil issue if ,in fact, that is what it is.
post #10 of 14 Old 03-10-2011, 07:03 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
hmmm to your knowledge did it have an engine swap at some point? this is a 96 xj right?
dukie564 is offline
post #11 of 14 Old 03-10-2011, 12:27 PM Thread Starter
96xjmyjoy
This has been discussed with a mechanic I go to and my uncle who is a gearhead. Yes it is a 96 classic. Should have the HO
post #12 of 14 Old 03-10-2011, 12:33 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
well then you don't need a MAT sensor, that was only used on early RENIX XJs. You can leave it disconnected.
Why someone would swap a renix intake onto your 96HO i don't know, but someone definitely has. They bolt up fine, but the ports are very mismatched. I'm sure your performance is suffering.
dukie564 is offline
post #13 of 14 Old 03-11-2011, 01:23 AM Thread Starter
96xjmyjoy
That would explain the "exhaust leak" then. I guess I will just get a newamifold and headers while I'm at it. Good to know this is a possibility. Will post up my final solution. How would I tell if the motor is the orig? HO stamped somewhere on it?
post #14 of 14 Old 03-11-2011, 04:44 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Dukie-The ports aren't that badly mis-matched. 1/4" max at the bottom of the port.
I did port match mine but I didn't have to.
cruiser54 is offline
Burning serious oil???? help AuburnXJ XJ Cherokee Technical Forum 8 02-14-2009 05:43 PM
Burning Oil?? Sciotojeeper XJ Cherokee Technical Forum 1 03-26-2008 11:48 AM
burning brakes of burning clutch? master999 XJ Cherokee Technical Forum 3 01-19-2008 11:50 AM
Burning more oil? RamboPants XJ Cherokee Technical Forum 8 01-01-2008 05:25 PM
burning cat... 95XJMIKE XJ Cherokee Technical Forum 5 09-07-2007 04:26 PM
