Quantcast bumpstop guide hits coil spring? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > bumpstop guide hits coil spring?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 07-20-2009, 08:43 PM   #1
crmaverick89
I just did a 3 inch rough country lift, and im getting rub from the bumpstop guide/assembly on the inside of my coil spring on the passenger side only. The bumpstop guide/assembly is more forward and not center in the coil, so when the coil stretches this bit rubs on the inside coil. The driver side one is center though with no rub, and also i did remove my trac bar and passenger control arm when installing the coils if that matters. Anyone know why this is happening and what I could do to adjust it center in the coil?
thanks
crmaverick89 is offline   Reply With Quote
Old 07-20-2009, 08:45 PM   #2
wes97
wes97's Avatar
sounds like you need to adjust your control arms . your axle is not foward as far as it should be.
wes97 is offline   Reply With Quote
Old 07-20-2009, 08:46 PM   #3
TJMunky
is the rubber bump stop hitting or is the piece of metal its jammed into hitting? if its the actual bump stop its easily fixed by pushing it away back towards center.
NIGHTCREW (RIP 01/28/09 - 07/22/09) #135
SILVER JEEP CLUB #120
TJMunky is offline   Reply With Quote
Old 07-20-2009, 09:07 PM   #4
crmaverick89
its the actual metal hitting the spring. Are the stock control arms adjustable at all? seems like i through it out of adjustment by taking it out, since the other side doesn't rub and i never took that one out
Old 07-20-2009, 10:31 PM   #5
foggybottombob
I heart bacon and pie
foggybottombob's Avatar
You can turn the coils a bit and move them some.
foggybottombob is offline   Reply With Quote
Old 06-14-2010, 11:22 PM   #6
ZJ5point2GCL
i know this is and old thread, but did you ever figure it out? my zj is doing this after a 4" lift only on the passengers side too
98 Deep Slate Niner- 6''s on 33's ---11 F150 Platinum Pearl White- Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote
Old 06-15-2010, 10:15 AM   #7
93gc40
main issue is that you need a longer Trackbar now that you lifted the Jeep to 3". You also need to adjust the caster. Did you do an alignment after the lift. here are instructions; Alignment
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline   Reply With Quote
Old 06-15-2010, 10:48 PM   #8
ZJ5point2GCL
I have an IRO double shear track bar, and the Axel is perfectly centered. And I have aligned it, I've set the tow in to 1/8th and the castor is good, but iam more concerned with the pinion angle though.
Glock Forum
