Bump Stops, etc for 2" + 31's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Bump Stops, etc for 2" + 31's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 08-03-2007, 09:45 AM   #1
Grinner
2010 JK Wrangler
I'm going to put the OME 2" suspension on my '01 XJ Sport. I'm going to run 31" BFG A/T's.
I know 31's are the limit for a 2" lift. It's mostly a dd with some trail riding. What should I do to keep the tires from rubbing my fenders and anything else?
Maybe add some bump top extensions? Or just not worry about it? If I disconnect the swaybar, would that increase the need for bump stop extensions?
Grinner is offline   Reply With Quote Quick reply to this message
Unread 08-03-2007, 10:06 AM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
With 31's on a 2" BB you will rip off the fender flares if you go offroad. Extend you bumpstops 1" and you should be fine.
Extended bumpstops prevent your tires from contacting the body and causing body damage and getting the treads cut on sharp sheetmetal. They also prevent damage to your shocks and springs. You will destroy your shocks if you slam them down until they are fully compressed. Your leaf springs will flex until they get inverted and then they will begin to lose their arch.
Hockey pucks are a cheap way to extend the front bumpstops and there are longer XJ factory bumpstops and/or you can add spacers to the rear.
Go here and read - http://members.aol.com/Stvns/XJhelp2.html
CJ7-Tim is offline   Reply With Quote Quick reply to this message
