Bump Stop Question - JeepForum.com
post #1 of 5 Old 08-14-2010, 10:51 AM Thread Starter
Beta144
1995 XJ Cherokee
Bump Stop Question
So I recently put on a Teraflex 1.5" spacer/shackle lift and when doing so noticed that my bump stops are literally rotting off. Should I get longer bump stops or just replace them with stock sized ones?
Beta144 is offline
post #2 of 5 Old 08-14-2010, 11:26 AM
93gc40
Yes you need new bumpstops. Do you have stock shocks or extended shocks? Shock length and tire rub is what determines what length you need. You want to keep the shocks from bottoming and the tire from rubbing when flexed.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 5 Old 08-14-2010, 11:34 AM
RockMonster
Easiest way to check for all kinds of clearance issues is remove all the springs, jack up the axle in different ways and bumpstop accordingly but if you don't care to get every inch of travel just go with what's recommended for the lift and tire size you are running.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #4 of 5 Old 08-14-2010, 01:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You should get slightly longer bumpstops or use a spacer. 1/2" to 3/4" longer is about right.
CJ7-Tim is offline
post #5 of 5 Old 11-10-2010, 07:10 AM Thread Starter
Beta144
1995 XJ Cherokee
alright thanks
Beta144 is offline
bump stop , cherokee
quick bump stop question woodie416 XJ Cherokee Technical Forum 5 01-12-2009 10:31 AM
bump stop help OKCTerror XJ Cherokee Technical Forum 6 10-31-2008 01:55 PM
front bump stop question WESJ XJ/MJ Cherokee Non-Technical Forum 2 08-14-2008 04:11 PM
Bump Stop mrboom XJ Cherokee Technical Forum 9 09-05-2007 05:51 PM
where to buy bump stop mell860930 XJ Cherokee Technical Forum 1 04-25-2006 07:10 AM
