Bump steer and other questions - Page 2 - JeepForum.com
post #16 of 18 Old 07-11-2012, 08:06 AM Thread Starter
Agony Wagon
1995 XJ Cherokee
What does it take to get them the same length? What else do I have to buy???
Agony Wagon is offline
post #17 of 18 Old 07-11-2012, 08:59 AM
foggybottombob
Don't worry about that. The effect of unequal length arms will be imperceptible from the picture you showed.
foggybottombob is offline
post #18 of 18 Old 07-11-2012, 04:50 PM
flying_bosun
Originally Posted by foggybottombob
I don't understand what any of this has to do with a plane as someone mentioned
Since everything else you said is nearly spot-on, I'll not muddy the waters, but will add this to clarify the "shared plane" concept. Notice in diagram 3 below the tb and dl are parallel, but not in the same plane (fore to aft) and not sharing a radial center, so their arcs of travel are not common and bumpsteer is inevitable. I hope it helps. Here's the link for the original thread: http://www.jeepforum.com/forum/f9/tr...tions-1356624/
Originally Posted by flying_bosun
At issue specifically was the "parallel" relationship required to avoid bump steer.
We've all heard that the TB and DL must be parallel and it's been suggested that with a DPA this could be accomplished by raising the axle end of the TB or by dropping the TB frame end. Initially this seemed reasonable to me from a geometric stand-point, but upon further examination it turns out not to be the case; the problem is that our axles articulate.
Here are some rough diagrams that may help some to understand what I mean.
For lack of a better explanation, bump steer occurs when the relative arcs' of travel don't share a (nearly) common center. This is because as the axle articulates, the push/pull forces acting on the axle via the track bar are at times contrary to the push/pull forces acting on the steering knuckle via the drag link.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
bump steer , track bar
bump steer getemduck XJ Cherokee Technical Forum 6 02-17-2011 03:09 PM
Bump steer questions? badlands1 XJ Cherokee Technical Forum 6 10-19-2010 05:39 PM
bump steer sawhead XJ Cherokee Technical Forum 12 08-12-2005 10:01 AM
Bump Steer? Alexandra1 XJ Cherokee Technical Forum 10 11-23-2004 04:17 PM
Bump steer? cheesycook XJ Cherokee Technical Forum 7 09-05-2003 04:01 PM
