Bump steer and other questions - JeepForum.com
post #1 of 18 Old 06-19-2012, 07:41 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
When I first installed my 3" lift, I had to constantly steer to keep moving in a straight line. It was recommended to me on here that I do an alignment. I did that, and it now tracks much better. Until I hit a bump. I can manage it alright. Have even gotten to where I can pretty much predict how the steering wheel is going to move before I even hit the bump. But I am pretty weary of it.
Does anything look out of whack with my steering setup? Note that I am using the stock track bar, and a relocation bracket that came with the lift kit. The kit (Skyjacker) also came with fixed LCAs. I don't know the length, but I recall them being longer than stock.
I've held off buying an adjustable track bar. The rear end is pretty stiff over bumps. My shackle angle isn't terrible but could use some improvement. I'm going to get a shackle relocation kit, which will probably add an inch or more to the rear lift height. So I figure I may as well bring it up to 4.5-5" either way, and then level out the front with some spacers.
Does it look like I need an adjustable track bar, or is something else off?
Will the track bars for 3.5-5" lifts be too long if my front is lifted only 3" (until I add the additional lift)?
Does an adjustable track bar require a body-side relocation bracket? I noticed some of them come with one, some don't.
Thanks,
Agony Wagon is offline
post #2 of 18 Old 06-19-2012, 08:25 PM
whitexj98
That relocation bracket is making your track bar unparallel to the drag link creating bump steer. Get an adjustable track bar with double scheer frame bracket and take off that axle end bracket.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #3 of 18 Old 06-19-2012, 08:53 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The track bar relocation bracket is probably the source of the problem if all your other suspension and steering parts are good. You also need to be sure that you have correct toe-in. 0 to 1/8" toe-in for a smaller lift.
Buy a double shear track bar that comes with a new frame side bracket. Iron Rock Off Road makes a very nice one.
CJ7-Tim is offline
post #4 of 18 Old 06-19-2012, 08:56 PM
flying_bosun
Parallel bars is not entirely correct, though it's often described as such. It's the plane between the mounting points that must be as near parallel as possible.
http://www.jeepforum.com/forum/f9/tr...tions-1356624/
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #5 of 18 Old 06-19-2012, 09:25 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
I thought they looked mostly parallel. I realized I should have been tracing endpoint-to-endpoint on the track bar.
Is making them parallel probably "good enough," at least while on the street?
I've seen some pictures where the tie rod looks parallel to the axle. Does this matter at all? I've noticed the front end lifts/lowers when simply turning the steering wheel.
post #6 of 18 Old 06-20-2012, 07:44 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
Bump steer.
post #7 of 18 Old 06-20-2012, 08:12 PM
whitexj98
Just like has been said, the axle bracket is creating bump steer.... you need a new track bar, anf ditch the lower bracket.
post #8 of 18 Old 06-20-2012, 08:32 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
I got that, but I have a couple other side questions up there. Thank you, though. Your picture confirms what I was thinking about how to verify parallel-ness.
post #9 of 18 Old 06-29-2012, 03:16 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
Double-shear
The frame side bracket has 3/4" drop to it. If I get rid of my axle-side bracket when I install the longer track bar and frame-side bracket, then it still won't be parallel, will it? I know the double-shear means more durability, but I'm primarily concerned with fixing how it handles.
post #10 of 18 Old 06-29-2012, 05:54 PM
CJ7-Tim
CJ7-Tim's Avatar
My IRO DS Track Bar was installed at 3.5" of lift. The steering was stock, no probelms, no bumpsteer. I now have 5.5" of lift, and still have stock steering, no problems, no bumpsteer.
CJ7-Tim is offline
post #11 of 18 Old 06-29-2012, 06:23 PM
flying_bosun
Sorry for the delayed reply. Parallel attachments (assuming shared plane) is what you need.
TR parallel to the axle has ZERO bearing on the issue. If the front end lifts and lowers when turning the wheel, you're not setup correctly.
― Ron Paul
post #12 of 18 Old 07-10-2012, 08:51 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
Ordered the IRO 1-5" Double Shear Track Bar Kit
I installed it last night. The steering is pretty tight. Returns to center way better than it has since I got it. No bump steer as far as I can tell now! Drove it about 15 miles through town so far. Handles fine, I think. Haven't made any adjustments yet, and I haven't been able to tell how it's tracking (no smooth, straight, flat roads in these suburbs it seems), but I'm sure I'll find out once I get on the highway. I'll be certain to re-torque all the bolts before I do that, though. I took a quick look after putting it on, and the axle might not be 100% centered, but it's close enough for right now.
Shipping was pretty quick. Everything was packed well. As soon as I pulled it out of the wrapping, I noticed there was a 1" scrape where something cut through the powder coating. I'll probably just hit that with some paint (or cover it up with the manufacturer's logo sticker that came in the box). And one of the two bolts included was too short to use on either end, and just a tad too fat to fit through the axle-side bracket. I would have had to drill or Dremel the hole just a teensy bit larger. I just reused the bolt that was on the old trackbar. It's only a year old, in good shape, and grade 8, IIRC. Other than those two little things, the kit was perfect. Installation was easier than I anticipated. None of the bolts gave me any difficulty getting off, including one I put red threadlocker on last summer to hold that damn Skyjacker relocation bracket...
post #13 of 18 Old 07-10-2012, 09:07 PM
rugsucka
Good stuff.
I threw a IRO double shear set up in last fall as my stock track bar was knackered, and I wanted to have future proof set up. I was 2" then, and just moved up to 5" now - adjusted it out and still have no bumpsteer and better clearance for the axle and the diff.
Because of the bend, I hung a bit under the axle before and would bang the top of the front diff cover on it off road. Now at 5" the bend is parallel to the axle, and has plenty more clearance over the differential.
Glad you put the money into a very good product. I also threw in an IRO tie rod this spring that I ordered at the same time - it's pure beef and may be getting the over the knuckle treatment soon.
rugsucka is offline
post #14 of 18 Old 07-10-2012, 09:36 PM Thread Starter
Agony Wagon
1995 XJ Cherokee
I'm at about 3" or so up front. I'll probably bump that up to about 4.5" to even out when I put shackle relocation boxes in the rear to fix my shackle angle. That should just about do it for me on height, so this track bar is all I need. When shopping for track bars before, I wasn't finding any that would fit both what I had now and what I will have. Glad someone makes one that gives me options.
post #15 of 18 Old 07-11-2012, 07:10 AM
foggybottombob
The reason you get bump steer when the track bar and drag link are not parallel is due to the fact that these two suspension members travel in an arc as the suspension flexes. So as either member moves through its arc, there is a horizontal component to the movement. The steeper the angle of either bar, the more the horizontal component. With the track bar at a steeper angle, when you hit a bump the track bar pushes the axle to the right further than the draglink pushes the steering arm to the right. So you will feel the steering pull to the left a bit as the two bars move up through their arc of travel. I don't understand what any of this has to do with a plane as someone mentioned but even if you have parallel steering members, when one of them is shorter than the other one you can still get bump steer due to the shorter member having a shorter horizontal movement than the longer member. This bump steer effect from unequal length bars is less pronounced than what you get when the two bars are not parallel.
foggybottombob is offline
bump steer , track bar
bump steer getemduck XJ Cherokee Technical Forum 6 02-17-2011 03:09 PM
Bump steer questions? badlands1 XJ Cherokee Technical Forum 6 10-19-2010 05:39 PM
bump steer sawhead XJ Cherokee Technical Forum 12 08-12-2005 10:01 AM
Bump Steer? Alexandra1 XJ Cherokee Technical Forum 10 11-23-2004 04:17 PM
Bump steer? cheesycook XJ Cherokee Technical Forum 7 09-05-2003 04:01 PM
