Build up the D30? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Build up the D30?
Bds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent PricesRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 10-16-2006, 10:33 PM   #1
00xj54
Build up the D30?
I'm a currently looking to buy and old Xj with D44 Rear. I'm gonna wanna put something better up front then the D30.
I don't think I I'll be able to find D44 Rear. My Club Pres says I can build up the D30 Front. Can someone give me more information this?
[I]00' XJ Sport. 4.0 I6.
[B]|15" Canyon Crawlers | 30x9.5 Bridgestone Dueler A/T Revos | [Lifted (2" Teraflex Spacers | 2.5" RE AAL | Edlebrocks IAS)| K&N Homebrew Intake | Flow Master 70 |Clear Corners/Side Markers| Class III Hidden Hitch | C4x4 Fronts Tow Hooks | JKS Discos | Surco Safari Rack | Hella 500s |
00xj54 is offline   Reply With Quote
Unread 10-16-2006, 11:06 PM   #2
EricsXJ
The Post man
EricsXJ's Avatar
Sure you can build the 30 and put as much money into it as you want. Whether it is worth it in the end depends on what you plan to do with it and your driving style.
Stock shafts with the larger 297x u-joints will typically hold up well to 33" tires.
Alloy shafts and 760x u-joints or better and you can run 35's.
Either way carry spares.
Along with that you can
gear it
lock it
diff protect it
manual hub it
Super 30 it
sleave it
truss it
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Unread 10-16-2006, 11:07 PM   #3
DirtyCommanche
And then blow the R&P.
Blah. Up to 33's sure. I wouldn't go larger.
DirtyCommanche is offline   Reply With Quote
Unread 10-17-2006, 09:15 PM   #4
00xj54
I just wanna put 35s on it. Oh and lock it.
Unread 10-17-2006, 09:23 PM   #5
DirtyCommanche
IMHO, it's on borrowed time.
Unread 10-17-2006, 09:39 PM   #6
00xj54
What's that mean?
Unread 10-17-2006, 09:42 PM   #7
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
it means he doesnt think you can do it.
go on naxja and ask there, theres countless guys there running 35s on a 30 without much trouble. i personally know a couple close friends doing it as well who dont wheel light by any means and have been trouble free. i as well will be doing this though i have more of a light foot myself. be smart and dont wheel stupid, thats half the battle
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Unread 10-17-2006, 09:44 PM   #8
XJohnnyC
Doesn't a 2000 have a low pinion D30?
XJohnnyC is offline   Reply With Quote
Unread 10-17-2006, 09:45 PM   #9
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
good call yes. a bit less desirable
Unread 10-17-2006, 09:47 PM   #10
DirtyCommanche
Don't get me started...
I guess it depends if you ever have to back up or not.
Unread 10-17-2006, 09:48 PM   #11
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
low pinions are good for autographing rocks
Unread 10-17-2006, 10:39 PM   #12
00xj54
So what if I wanted to start on this, like tomorrow. How do I go about it?
Unread 10-17-2006, 10:43 PM   #13
DirtyCommanche
Pull the D30 out of the jeep. Deposite it in neighbours front yard. Acquire a D44 from an 80's Grand Wagoneer.
Unread 10-17-2006, 11:07 PM   #14
Jeepernick
2008 XJ Cherokee
x2
Jeepernick is offline   Reply With Quote
Unread 10-17-2006, 11:48 PM   #15
EricsXJ
The Post man
EricsXJ's Avatar
If anyone doubts that you can build a 30 to hold up to 35's, take a look at the trail ride photos on my website and tell me that it can't be done... because I have been on 35's for over a year, I wheel it, and it HAS held up fine.
Its all how you wheel - don't just put the throttle down on everything thinking that's what you need to get through, otherwise no this won't work for you.
I'm also locked (ARBs) and in my opinion its less likely to cause R&P breakage because you have less tire spin. (see comments above...) With open diffs when you are spinning tires a lot and then suddenly they catch and get traction is what hurts.
That being said, I think if you want to build a 30... AT LEAST find a HP 30. They are a direct swap and you'll be much better off in the end.
Eric
