The build finally begins... - JeepForum.com
post #1 of 28 Old 03-02-2009, 11:13 PM Thread Starter
jonesinxj
Ok guys, I have been looking thru this forum pretty much every day since I found it and have been drooling over some of the rides that ya'll have done!
Well to start off I bought a 88 XJ last year for a cheap 350 bucks!! Its was very basic, but it came with a 4.0 and a stick! When i was looking at it the guy who owned it stating that it was over heating and his mechanic said it was the head gasket... well i decided to buy it and towed it home, did some of my own mechanic work and found out that it was not overheating at all and the only thing that was wrong with it was the temp sending unit!!! So it is and will be a daily driver and weekend play toy, about the only thing I have done to it has been a 2 in Budget lift and wheels and tires.
Well tonight I scored another great deal! Scored a RE 3.5 super ride kit, with additional upper control arms, Track bar with a hiem joint with the modified mounting bracket and skyjacker shocks which everything is BRAND NEW never installed and the best part, I got a ford 8.8 witha tru trac locker and 3.73 gears along with 3.73 gears with the 3rd member for a dana 30..... and the final price 600!!
I already have a HP non disconnect dana 30 with all new steering with 3.73 gears that Ive been waiting to put in when i got my lift.
Over the next few weeks I will be completing the project (I travel alot for work so not a whole lot of time) I will keep you updated with pictures.
Here is a couple pics of when i first got it to what it looks like now! Also if you have any suggestions or advise Im all ears.
Thanks guys
Just after I first bought it
http://i64.photobucket.com/albums/h1...b611c72ee4.jpg
after 2 in BB and rims and tires
http://i64.photobucket.com/albums/h1...s/HPIM0967.jpg
http://i64.photobucket.com/albums/h1...HPIM0968-1.jpg
and finally the new parts
http://i64.photobucket.com/albums/h1...s/HPIM0977.jpg
http://i64.photobucket.com/albums/h1...s/HPIM0978.jpg
jonesinxj is offline
post #2 of 28 Old 03-03-2009, 05:51 AM
lurkeryj
1997 XJ Cherokee
sounds like a pretty sick budget build! keep us updated and make sure to kick the crap out of it after you get done
lurkeryj is offline
post #3 of 28 Old 03-03-2009, 10:12 PM Thread Starter
jonesinxj
So I got started on the tear down tonight!! I ripped the rear axle out and so far I only have the rear springs in. But the good news is Ive decided to go 5.5 with the shackle and spacer that i already have. WHOO HOO!! Figured I might as well go big or go home! I will go and beat on it a little, but for the most part its a airport runner.... Until the carnage begins! haha
Here are a few pics of my progress
http://i64.photobucket.com/albums/h1...s/HPIM0980.jpg
http://i64.photobucket.com/albums/h1...s/HPIM0979.jpg
http://i64.photobucket.com/albums/h1...s/HPIM0981.jpg
http://i64.photobucket.com/albums/h1...s/HPIM0983.jpg
post #4 of 28 Old 03-03-2009, 11:00 PM
91xjgawes
Thanks guys
clickless...
looking great
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline
post #5 of 28 Old 03-03-2009, 11:02 PM
91xjgawes
and again...
post #6 of 28 Old 03-03-2009, 11:04 PM
99Greenmachine
looks like you got a steal
have fun with it!
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #7 of 28 Old 03-04-2009, 12:26 AM Thread Starter
jonesinxj
Ok guys I have a question, I was sitting here talkin to a friend and since I am going up to 5.5 inches of lift, obviously I am worried about my driveline issues. Ive heard of alot of guys now (sammies and yotas) are putting a spacer between the output shaft of the rear axle and spicer adapter? Has anyone heard of this being done on these rigs? And if so did it work? I was thinking of this since I have the 8.8 out back now
Thanks
post #8 of 28 Old 03-04-2009, 01:21 AM
jmitywhitey
1988 MJ Comanche
no it will not work because the transfer case you have has a slip yoke. the samurais have a fixed yoke the spacers are to give you a more usable amount of slip yoke so you dont need a longer drive shaft. you will need at a minimum a transfer case drop and most likely a slip yoke eliminator and a double cardin drive shaft
jmitywhitey is offline
post #9 of 28 Old 03-04-2009, 09:37 AM
T4STE
you might also want to adrress that trac bar you got. if thats the one for the 3.5 kit, you might need the one for the 5.5 kit to match. lookin good, i like that grey color on the xj
16 WK2 75th Anniversary-Lucille the Albino Rhino
96 XJ Sport-Rosemary the Perrywinkle People Eater
T4STE is offline
post #10 of 28 Old 03-04-2009, 10:14 AM
XJH-007
XJH-007's Avatar
Nonsense.
I ran 6+" with a 1" T-case drop and about 4 degrees pinion angle for years with the stock driveshaft.
Ate up the top U-joint about once a year but it ran vibe free.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #11 of 28 Old 03-04-2009, 10:22 AM Thread Starter
jonesinxj
(quote)Ok guys I have a question, I was sitting here talkin to a friend and since I am going up to 5.5 inches of lift, obviously I am worried about my driveline issues. Ive heard of alot of guys now (sammies and yotas) are putting a spacer between the output shaft of the rear axle and spicer adapter? Has anyone heard of this being done on these rigs? And if so did it work? I was thinking of this since I have the 8.8 out back now
Thanks
(quote) no it will not work because the transfer case you have has a slip yoke. the samurais have a fixed yoke the spacers are to give you a more usable amount of slip yoke so you dont need a longer drive shaft. you will need at a minimum a transfer case drop and most likely a slip yoke eliminator and a double cardin drive shaft
I think you may have misread my question, yes I know that I have a slip yoke on my transfer case, but with the new 8.8 rear end that i have it does have the fixed yolk, and that is were I was thinkin that I could put the spacer. In my head I can see how it would work, because with the spacer on the fixed yolk on the 8.8 wouldnt it slide the slip yolk back into the transfer case and as long as my pinion angle is right I shouldnt have any binding (in theory) im just wondering if anyone has already done this.
And you are right T4STE I am probably going to have to address the trac bar issue, and if anyone is looking to part with some control arm drop brackets
post #12 of 28 Old 03-05-2009, 01:47 AM
jmitywhitey
1988 MJ Comanche
the length of the drive shaft may not be the problem but more likely the drive line angles. if you were to need the extra length i say go for it and if you get vibes look into a SYE. you may need to get it custom made as i dont think the sami or yota ones will work and make sure you use very good hardware to mount
post #13 of 28 Old 03-05-2009, 11:22 AM Thread Starter
jonesinxj
thanks for the reply guys, i will just have to wait and see and run it to see what I am gonna do... as I keep thinking about this I may just run the 3.5 for now until I can afford to get a few much needed extras like, control arm drop brackets and a sye.
Anothere quick update, I am taking the rearend to my buddies tonight and havin him put a nice thick weld around the housing to the tubes so they wont spin. then I will come home, clean everything up and prime around the welds then paint everything.
post #14 of 28 Old 03-05-2009, 12:29 PM
91xjgawes
that is a great idea...
post #15 of 28 Old 03-07-2009, 01:08 AM Thread Starter
jonesinxj
well tonight was a pretty sucessful night. I removed the 2 in drop shackles and replaced them with the stock ones (temporary) I also tore out the complete front end end suspension and axle.
Tomorrow included removing my oil pan and replacing the rear main, since everything is soo easily accessable right now. Also installing the 8.8, connecting the brake lines and e-brake cables, replacing U-joints, torque everything down in the back.
In the front mounting everything to the frame loosly, grease everything on the new dana 30 non disco, slide it under the jeep and start connecting everything. Today I did pick up YJ front brake lines. We will see how they work. Hopefully I will have everything buttoned up torqued down and road worthy by tomorrow night, then monday morning i can go get a front end alignment. Oh yeah I guess I will have to bleed the brake system too..yippee
Well Im off to get some much needed rest! I will have pics up tomorrow
Build up Begins!! bmyohn XJ Cherokee Technical Forum 717 05-14-2015 09:05 AM
finally my build is coming together brandonS4685 XJ Cherokee Technical Forum 6 03-16-2009 08:17 PM
build finally done...for now(pics) iwishihad1 XJ Cherokee Technical Forum 18 01-09-2009 09:54 PM
Finally got my build sheet! xjpilot XJ Cherokee Technical Forum 8 09-27-2007 05:54 PM
The build begins Wolf92XJ XJ Cherokee Technical Forum 1 03-01-2007 04:28 AM
