Budget Builds: What junkyard parts will fit an XJ? - Page 7 - JeepForum.com
 6Likes
post #91 of 709 Old 09-11-2009, 08:22 AM
mattathayde
Originally Posted by yjjason View Post
2dr sport Explorers were common to have 4:10's and lsd, also dont have control arms only leaf springs!
SOB, of course i had to drive around with a 2 door exploder w/o an LSD... that or the ford LSD is worthless, always spun tires/one wheel spin, no freaking weight in the back end
-matt
mattathayde is offline
post #92 of 709 Old 09-11-2009, 08:25 AM Thread Starter
RedZeppelinXJ
awesome! how do we make this a sticky?
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #93 of 709 Old 09-12-2009, 06:10 AM
rubiwannabe
5.0 injectors
Other than having more holes in the injector..whats the advantage?...smoother idle?..more power?..better mpg's?.....
rubiwannabe is offline
post #94 of 709 Old 09-12-2009, 10:45 AM
-Shoey-
2010 KK Liberty
I know they make the 4.0 run better, but I was curious about mpg's as well..
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #95 of 709 Old 09-12-2009, 05:18 PM
natertots
1990 XJ Cherokee
Some have said better mileage and some claim worse. Im going to guess it is a step up for us renix owners and maybe down for the newer HOs. But more power and smoother idle is for everyone.
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #96 of 709 Old 09-12-2009, 07:18 PM
ep191
Originally Posted by JGriff99xj View Post
how can you use wj rotors and calipers if the bolt pattern is different?
your bolt pattern lies in your hubs, the calipers and rotors will bolt directly to the hubs
ep191 is offline
post #97 of 709 Old 09-12-2009, 07:23 PM
USMC_XJ
2003 WJ
You can use 87-95 Dakota leaf springs for a bastard pack also. Same with the S10 packs. Good for around 4-5" depending how you do it.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #98 of 709 Old 09-12-2009, 08:45 PM
mattathayde
i would be there is also a bit of the "oooo theres more power... weeeeeeeee" as they slam the gas. kinda like the CAIs
i would assume it gives better/more even and complete burn due to the better spray pattern
-matt
post #99 of 709 Old 09-12-2009, 10:22 PM
96jeepin
Sticky!!!!
96jeepin is offline
post #100 of 709 Old 09-13-2009, 01:44 PM
Apostle
Anyone know if a 97+ heater control unit (dashboard buttons) can be swapped into a +96
not a big fan of slidding bars, would rather have rotor buttons
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #101 of 709 Old 09-13-2009, 04:26 PM
newxj
1990 XJ Cherokee
anyone have part numbers for the YJ e-brake cables?
newxj is offline
post #102 of 709 Old 09-13-2009, 07:00 PM
The Shoveller
1988 XJ Cherokee
97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails.
My 88 Laredo came with folding mirrors.
88 XJ Laredo under construction
The Shoveller is offline
post #103 of 709 Old 09-13-2009, 07:04 PM
The Shoveller
1988 XJ Cherokee
Or any other makes/models?
post #104 of 709 Old 09-13-2009, 07:45 PM
mattathayde
AFAIK they all run on vac controls, so depending on how the tubing runs and if the control system is the same other than the control you can probably get it to work... granted ive never pulled it to see
-matt
post #105 of 709 Old 09-13-2009, 08:03 PM
YJSXJ
1993 XJ Cherokee
Also, you can also get a 97+ center Console to work in a pre-97 with slight modofication. I did it, Ebrake works AND i have cupholders, and now i have 2 ashtrays,................im so cool.
looking for 33x12.5x18 tires.
Bruiser -- 93 XJ Sport. 9.5" lift on 35"" Claws, Locked front & Rear, and some other crap. Rolled it
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Sold it
1999 WJ Limited V8. 4" Mix-n-Match Lift. Nothing special.
YJSXJ is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
