Budget Builds: What junkyard parts will fit an XJ? - Page 6 - JeepForum.com
 6Likes
post #76 of 709 Old 09-09-2009, 11:06 AM Thread Starter
RedZeppelinXJ
can some one post a link to a build thread where the manual control is used on the vacuum disco?
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #77 of 709 Old 09-09-2009, 11:23 AM
BRad704
Nothing to see here...
BRad704's Avatar
try a YJ section.... i remember the front diff on my 91 being vac and people talking about ways around it over there..
BRad704 is offline
post #78 of 709 Old 09-09-2009, 01:50 PM
ajduby
1989 XJ Cherokee
Junkyard parts
I started out lifting the front of my 89 XJ with coilsprings off of a '79 F150 and got 4.5".
I was told the ride would be stiff but they are great and have enough flex. I now acquired coils off of a '79 Bronco with 4" lift which will put my rig at about 8-9".
'89 xj
4.5" home brew lift
33x12.5x15
ajduby is offline
post #79 of 709 Old 09-09-2009, 04:33 PM Thread Starter
RedZeppelinXJ
Here is the latest re-cap of what we have found:
Suspension & Lift:
1. ZJ V8 Upcountry Coils = 1-1.5" lift
2. F-150/Bronco Coils ('79-ish) = 4-4.5" lift
3. S10 leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift
4. JK shocks = slight mod to fit 2-4" lift
5. MJ Shackles = 1/2" lift
6. Camaro Spring Isolators = 1.5" lift
Brakes:
1. WJ brake booster
2. WJ Master Cylinder
3. YJ Brake Lines = 3-4" longer
4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts)
5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims)
Axles:
1. Ford 8.8 inch ('97+) = need spring & shock mounts (4.10, LSD, Disc Brakes)
2. XJ I-4 & V6 = 4.10 gears (some have 4.56) may have vacuum discos
Front End & Steering:
1. ZJ V8 Tierods = beefier & bolt in
2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering
3. Durango Steering Box = beefier
4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding)
5. WJ LCA's = more tire clearance (some grinding required)
6. ZJ pitman arm = 1 inch drop over stock
Engine Performance:
1. Newer XJ intakes (may require some modification)
2. Mustang 5.0 Injectors = bolt in (have 4 holes instead of 1, more fuel, better spray)
3. ZJ V8 alternator = more power to run accessories (some grinding required)
4. Taurus Dual Electric Fans ('96-98) = replaces mechanical fan, better cooling
Other:
1. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing)
2. Lebaron or laser hood vents = help keep ur 4.0 cool
3. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails.
4. MJ Bucket seats = tilt forward, bolt in to at least older XJ's
5. ZJ gas tank skid = can be modified to fit 97+
6. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style)
7. GM power antennas replace your broken XJ's with little modification
8. 5spd crossmembers give 3/4 inch tcase drop on autos with no loss in ground clearance
9. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an Mj overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core.
*view previous posts for more details.....and feel free to ask questions
post #80 of 709 Old 09-09-2009, 05:07 PM
Bam-Bam
Hey nice thread man lots of good stuff thanks
Bam-Bam is offline
post #81 of 709 Old 09-09-2009, 06:51 PM
mattathayde
Dana 30 Vacuum Disconnect - Jp Magazine shows some options how to rebuild/replace the vac disconnect, one being a posi lock
-matt
mattathayde is offline
post #82 of 709 Old 09-10-2009, 07:41 AM
Blazin Den
i used some of Zeppelin recap and added links to them.
http://www.jeepforum.com/forum/f11/b...-links-854723/
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #83 of 709 Old 09-10-2009, 02:10 PM
natertots
1990 XJ Cherokee
Awesome!! Thanks for taking the time!
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #84 of 709 Old 09-10-2009, 03:00 PM
-Shoey-
2010 KK Liberty
Awesome thread, should be a sticky.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #85 of 709 Old 09-10-2009, 03:14 PM Thread Starter
RedZeppelinXJ
Thanks for taking the time dude.....can you put that into this thread at all? that way everything is all in one place for convenience?
I wanna thank you and everyone else for adding to this thread....there is a ton of great info from you guys!
post #86 of 709 Old 09-10-2009, 05:27 PM
JGriff99xj
how can you use wj rotors and calipers if the bolt pattern is different?
JGriff99xj is offline
post #87 of 709 Old 09-10-2009, 06:25 PM Thread Starter
RedZeppelinXJ
Griff.....check out this build thread it should have the info you need...... WJ Brakes & Steering Conversion for XJ
post #88 of 709 Old 09-10-2009, 09:36 PM
Blazin Den
i will try and add the links into this post tomm
post #89 of 709 Old 09-10-2009, 10:23 PM
natertots
1990 XJ Cherokee
Here ya go just copy and pasted your post
I have read through the Budget Builds: What junkyard parts will fit an XJ? post and have used Zeppelin recap list, well most of it, and searched for what I thought was the best links for each one. You guys can add links later but heres the best ones that I came up with:
Suspension & Lift:
Home Brew Budget Boost
ZJ coils on an XJ - Jeep Cherokee Forum
XJ coil question + some pics - Pirate4x4.Com Bulletin Board
Jeep Cherokee Suspension - XJ Budget Lift - "How-To" Lift Your Jeep Cherokee XJ 4" on a Budget
S10 Springs "Bastard Pack" - Jeep Cherokee Forum
$11 Bastard Leaf Pack Writeup. *Tons of pics* - NAXJA Forums -::- North American XJ Association
FitchVA’s Jeep Page Writeups Home-Brew 2″ Budget Boost (BBB)
4. Dakota Leaf Springs
Brakes:
1. Xj Brake Booster Upgrade Pre 96
MADXJ go to the brake section
2. WJ Brake Upgrades
XJ Cherokee Conversion to WJ Front Brakes & Steering
WJ Grand Cherokee Master Cylinder and Booster Upgrade How-To - Jeep Cherokee Forum
4. WJ Rotors/Calipers = bigger brakes and more stopping power
Jeeps "R" Us - Have you climbed a rock today?
Axles:
Ford 8.8 Axle in YJ (for a YJ but same concept applies)
BC4x4.COM four wheel drive, 4x4, offroad and fourwheeling site. ( xj version)
ZJ Tie Rod Upgrade - Jeep Cherokee Forum
Durango Steering Box Upgrade - Jeep Cherokee Forum
4. WJ LCA's = more tire clearance (some grinding required)
WJ Lower Control Arms in an XJ
5. ZJ pitman arm = 1 inch drop over stock
ZJ Steering - NAXJA Forums -::- North American XJ Association
Do I need a drop pitman arm?? - Jeep Cherokee Forum
Engine Performance:
4.0L 99+ intake manifold swap with REAL DYNO NUMBERS! - MallCrawlin.com Forums
Swapping to a 2000 Inlet Manifold
http://www.jeepforum.com/forum/f11/m...ectors-666038/
alternator upgrade? - Jeep Cherokee Forum
alternator swap - NAXJA Forums -::- North American XJ Association
Taurus Fan Install
Other:
The AX-5 to AX-15 Swap Thread - NAXJA Forums -::- North American XJ Association
http://www.jeepforum.com/forum/f11/h...w-pics-472815/
3. 97+ Door Swap on older models
Jeep Cherokee XJ Door Upgrade - Jp Magazine
http://www.jeepforum.com/forum/f53/w...manche-460083/
XJ Gas Tank Skid Plate Install
This is by no means the only links that i found but ones that have pictures and mabe better descriptions to help out others who are trying to do the same thing. If you guys want to add to the list you can but put up links to what you find.
Baileydog13 likes this.
post #90 of 709 Old 09-11-2009, 12:17 AM
yjjason
X-Y-J-Con
yjjason's Avatar
Originally Posted by robin1t2002 View Post
From the factory, all Ford rear differentials have a small metal plate attached by one of the cover bolts. This will have the gear ratio. If it has a limited slip, it will have a "L" stamped beside the gear ratio. Explorers and all other Fords, could be ordered with a number of gear ratios. I personally never seen one with 4:10. Most had 3:55 or 3:73. If the metal plate has been removed, you will need to remove the cover to find out the ratio/LSD.
2dr sport Explorers were common to have 4:10's and lsd, also dont have control arms only leaf springs!
88yj-94 4.0-ax15-2004 rubicon f/r axles-4.10's-factory air lockers-33"D!ck Cepek Crushers
yjjason is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
