Budget Builds: What junkyard parts will fit an XJ? - Page 44 - JeepForum.com
 1Likes
post #646 of 709 Old 09-18-2013, 02:26 PM
Charley3
Originally Posted by remmons View Post
I've seen stacked blocks get spit out under some severe axle wrap when the rear end starts hopping around violently. Believe me, this is not a pretty sight.
Sounds entertaining.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #647 of 709 Old 09-20-2013, 09:42 AM
remmons
It can be.
Robert.
remmons is offline
post #648 of 709 Old 11-21-2013, 01:05 AM
iowassfan
Originally Posted by DoctorTim View Post
ZJ rear lower control arms are also good for a lift on an XJ, usually 1-2" longer. no grinding required
How much lift are these good for? Looking at doing a 3" JY lift. Any links to write ups or pics?
iowassfan is offline
post #649 of 709 Old 12-03-2013, 07:07 PM
VicOfAges
Originally Posted by RedZeppelinXJ View Post
1.MJ/2 Door XJ Bucket seats = tilt forward, near bolt in
What does he mean with "near bolt in"? I've got a line on a 1990 2 door seat and I'm curious if the seat will fit in a 4 door 96.
VicOfAges is offline
post #650 of 709 Old 02-16-2014, 08:37 PM
1stbeer
can you take a new xj rear end w/disc and near bolt it to a 99 xj? need help cause i have two broken leafs and want to do a small lift just want to do it all at once instead of putting er down 2 or 3 times
1stbeer is offline
post #651 of 709 Old 02-16-2014, 10:28 PM
uberxj92
1992 XJ Cherokee
It won't bolt right in. But you can swap the mounts then it will
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #652 of 709 Old 02-16-2014, 10:29 PM
uberxj92
1992 XJ Cherokee
No
uberxj92 is offline
post #653 of 709 Old 02-27-2014, 09:22 PM
Hjkjohn
Jeep XJ back door shocks
Just at the local pick n pull today and got some rear hatch shocks off a 1996 ford explorer. They were the exact same length as my oem shocks. The ends screw off the oem and screw right on to the explorer shocks. Completely bolt in and same exact length on my 1997 jeep XJ. Now I have VERY BEEFY rear hatch shocks that I'm confident will never go out. My hatch pretty much opens itself no haha. No more head balancing I previously read that putting the explorer shocks on my 97 would need slight modification and want to state that they are bolt in on any 97-01 XJ can verify for any earlier years.
Hjkjohn is offline
post #654 of 709 Old 03-01-2014, 05:16 PM
VegasGT
1988 MJ Comanche
Not sure if its been mentioned or not but Ford Ranger shackles fit. They are roughly the same dimensions as JKS 1" lift shackles but way cheaper even new, and plentiful in junkyards. Im running a pair off a 2000 model but many years should be the same.
They work great with relocation brackets.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #655 of 709 Old 06-16-2014, 12:19 PM
94purp
Not sure if it was covered but stock explorer/ranger rims backspacing is 4.25 compared to stock xj at 5.25 so an extra inch for clearance for cheap.
94purp is offline
post #656 of 709 Old 07-18-2014, 08:00 PM
psychone
instrument panel with gauges can be swapped for idiot light panel. for sure 91-96. requires changing out oil sender and temp sender on back of head.
psychone is offline
post #657 of 709 Old 07-31-2014, 10:14 AM
bluejunior
bluejunior's Avatar
Not sure if this is covered, but you can get Dodge 160 amp alternators into an XJ with no more grinding than required for the ZJ 136amp. You should (but don't need to) swap the pulley from your XJ alt onto the dodge one. You want the one off of the dodge 5.9L V8. I got mine for my 01 from a 2003 Durango in a junkyard for 40 bucks.
Edit only certain year models woek with XJ pigtails, but you can make a wide range if you are comfortable with a little wiring work
Lifted, Locked, Stiffened
bluejunior is online now
post #658 of 709 Old 08-01-2014, 08:15 AM
Riley/MN
I did a search on car-part.com and they only list a 136 amp in the dakota. I wonder if the 160 was a special package or something?
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #659 of 709 Old 08-01-2014, 09:20 AM
bluejunior
bluejunior's Avatar
Durango, not Dakota. It has to be a 5.9 Durango, although maybe a couple others came with the 160amp, I've never been able to confirm.
post #660 of 709 Old 08-01-2014, 09:42 AM
Riley/MN
Ah - Gotcha...
~Riley
TMA MN State Rep
Riley/MN is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
