Budget Builds: What junkyard parts will fit an XJ? - Page 4 - JeepForum.com
 6Likes
post #46 of 709 Old 09-03-2009, 06:49 PM
mbood82
mbood82's Avatar
Originally Posted by xjfever View Post
The V8ZJ coils are a direct swap, but only give around 1" of lift. New lift coils can be had for around 100.00 and are a better option than ZJ coils and spacers.
FWIW, I've lifted three separate cherokees with the V8 ZJ coils, all three of them got 1.5" of lift. I know one set of the coils came out of an upcountry ZJ from a friend but the other set of coils I pulled myself out of a V8 with 200k+ miles on it in the junkyard. It may have been an upcountry but didn't look like it.
Yes, I know 2 does not equal 3 but the set I pulled myself I ran in my '97 XJ until I bought real lift springs for it and put them into my wifes '99.
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline
post #47 of 709 Old 09-04-2009, 09:03 AM Thread Starter
RedZeppelinXJ
Here is the latest re-cap of what we have found:
Confirmed Mods:
ZJ V8 Upcountry front coils = net about 1-1.5 inch lift
S10 rear leaf packs (cut eyes off main & bolt springs to XJ main) = 3-4" lift
JK shocks = slight mod to fit 2-4" lift
WJ brake booster & master cylinder = stop faster
YJ brake lines = bolt in & 3-4" longer
ZJ shift knob = replaces XJ knob
'97+ Ford 8.8" rear (need new spring perches, shock & track bar mounts) = 4.10 gears, LSD, disc brakes
Newer Intakes (with modification)
V8 ZJ Tierods = stronger than I6
WJ Knuckles/tierods/draglink (steering upgrade....gives you crossover steering)
WJ Rotors/Calipers = biggers brakes and more stopping power
Mustang 5.0 Injectors = bolt in and have 4 holes instead of 1 for more fuel and better spray pattern
Durango steering box = beefier than XJ box
ZJ V8 alternator (some grinding required) = more power for those of us with lots of accessories
WJ LCA's (slight grinding required) = more tire clearance
*view previous posts for more details.....and feel free to ask questions
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #48 of 709 Old 09-04-2009, 09:06 AM
XJKyle1389
MJ leaf springs lift an XJ in the rear 4 inches (supposedly). Bolts right up too.
XJKyle1389 is offline
post #49 of 709 Old 09-04-2009, 11:49 AM
cheapfix
1991 XJ Cherokee
I have ZJ coils in the front -- about an inch of lift over stock for me. However, I am switching back to stock 6cyl cherokee springs -- the ZJ ones are too stiff. The ride is terrible, you will loose fillings. Maybe OK if you are planning a heavy bumper/winch up front...
Recovering moparholic
cheapfix is offline
post #50 of 709 Old 09-04-2009, 12:01 PM
newxj
1990 XJ Cherokee
Quick questions regarding steering wheels... from what vehicles can swap steering wheels over? My jeep has the air bag in the wheel i would like to get rid of the wheel.
I was told the Jeep uses the same spline count as GM so that leads me to believe I could use any GM steering wheel...?
Confirm or Deny please.
newxj is offline
post #51 of 709 Old 09-04-2009, 07:14 PM
natertots
1990 XJ Cherokee
is this true?
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #52 of 709 Old 09-04-2009, 07:28 PM
XJohnnyC
XJohnnyC's Avatar
That's a load of doo-doo. MJ leaf packs are longer than XJ leaf packs and will not bolt up. You could possibly use an MJ main leaf as an AAL to gain some lift.
XJohnnyC is offline
post #53 of 709 Old 09-05-2009, 12:18 PM
portcityXJ
1995 XJ Cherokee
MJ shackle will give about 1/2" of lift on an XJ
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #54 of 709 Old 09-05-2009, 12:32 PM
tjjeepwrench978
1997 XJ Cherokee
94 and up dakota v6 ax-15 is a direct fit change the bellhousing on 94 and up fits all the jeeps I just threw one in a 95 wrang
tjjeepwrench978 is offline
post #55 of 709 Old 09-05-2009, 04:27 PM
YJSXJ
1993 XJ Cherokee
XjohnnyC, do you also have the 97+ fenders?? if not do you have a pic of where the older fenders meet the newer header panel??? I'm curious as to how it looks. thanks in advance.
looking for 33x12.5x18 tires.
Bruiser -- 93 XJ Sport. 9.5" lift on 35"" Claws, Locked front & Rear, and some other crap. Rolled it
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Sold it
1999 WJ Limited V8. 4" Mix-n-Match Lift. Nothing special.
YJSXJ is offline
post #56 of 709 Old 09-05-2009, 04:57 PM
g-off70
will the mustang injectors also work in a 4.0 WJ?
g-off70 is offline
post #57 of 709 Old 09-05-2009, 05:02 PM
USMC_XJ
2003 WJ
Do the 5.0 injectors add more horsepower and torque? Any specific years to look for?
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #58 of 709 Old 09-05-2009, 06:08 PM
ep191
Originally Posted by brandontrek View Post
will the WJ brakes clear the stock 15 inch wheels?
yep 10char
ep191 is offline
post #59 of 709 Old 09-06-2009, 10:45 AM
XJcrazy00
OP, you should edit the first post in this thread to include all of your findings. That would make it REALLY easy for beginners on a budget.
Originally Posted by mcantar18c View Post
This actually all started out with the thought of "My left arm is getting way more tan than my right arm is... I want a sunroof!"
XJcrazy00 is offline
post #60 of 709 Old 09-06-2009, 02:44 PM Thread Starter
RedZeppelinXJ
ok first thread is edited.....i'll post updates there from now on too
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
