Budget Builds: What junkyard parts will fit an XJ? - Page 3 - JeepForum.com
 6Likes
post #31 of 709 Old 09-03-2009, 07:57 AM
YJSXJ
1993 XJ Cherokee
What's the advantage of a durango steering box??
looking for 33x12.5x18 tires.
Bruiser -- 93 XJ Sport. 9.5" lift on 35"" Claws, Locked front & Rear, and some other crap. Rolled it
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Sold it
1999 WJ Limited V8. 4" Mix-n-Match Lift. Nothing special.
YJSXJ is offline
post #32 of 709 Old 09-03-2009, 07:58 AM
99Greenmachine
Beefier mainly
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #33 of 709 Old 09-03-2009, 08:04 AM
YJSXJ
1993 XJ Cherokee
Ahhhh. Gotcha
YJSXJ is offline
post #34 of 709 Old 09-03-2009, 08:30 AM
brandontrek
will the WJ brakes clear the stock 15 inch wheels?
brandontrek is offline
post #35 of 709 Old 09-03-2009, 08:51 AM
Kettles
Sweet, I just glanced at my build sheet, and I apparently have a 124 Amp Alternator. So I guess not everyone has 90 amp ones.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #36 of 709 Old 09-03-2009, 09:00 AM
brandontrek
how can you tell if you have a high output alternator? what is the part number?
post #37 of 709 Old 09-03-2009, 09:05 AM
Kettles
It says on my build sheet "124 Amp Alternator". 8th item on the sheet for me.
_=====o000o
Kettles is offline
post #38 of 709 Old 09-03-2009, 09:09 AM
brandontrek
I have no build sheet
post #39 of 709 Old 09-03-2009, 09:13 AM
Kettles
Get one. Email jeep : Contact Jeep and ask for a build sheet
_=====o000o
Kettles is offline
post #40 of 709 Old 09-03-2009, 09:37 AM
brandontrek
working on it as we speak...
heading to the local bone yards this weekend and looking to have some fun
post #41 of 709 Old 09-03-2009, 10:20 AM
PowderHound
2003 WJ
WJ Grand Cherokee lower control arms = extra clearance for wider tires. The WJ LCA's are the same length, and have an S-bend specifically for tire clearance. You have to slightly grind the bushings to xj width. Besides that they are a direct bolt on.
PowderHound is offline
post #42 of 709 Old 09-03-2009, 11:44 AM
natertots
1990 XJ Cherokee
totally forgot about that one. Good catch!
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #43 of 709 Old 09-03-2009, 11:56 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
For those with older XJ's 94-down, swapping in a 95-up master cylinder/brake booster is an upgrade for better brakes. The 95-up are dual diaphram compared to 94-down single diaphram. The 95-up front axles also came with bigger u-joints compared to the 94-down. But if your 94-lower has ABS it already has the larger u-joints.
xjfever is offline
post #44 of 709 Old 09-03-2009, 12:14 PM
natertots
1990 XJ Cherokee
You can also use the MC and brake booster out of a grand cherokee with a small grind of the rod. (and its just for the brake lights to come on at the correct time) Grand Cherokee Master Cylinder and Brake Booster Swap - NAXJA Forums -::- North American XJ Association
from left to right 89 MJ, 97 XJ, 00 WJ
EDIT: okay I must have missed that it was mentioned cause just saw this already in the confirmed list.
post #45 of 709 Old 09-03-2009, 06:28 PM
vtine523
1992 XJ Cherokee
Originally Posted by 99Greenmachine View Post
Beefier mainly
that bolts right up correct??
** http://southsidejeepers.freeforums.org/ ** http://southsidejeepers.wetpaint.com/ **
vtine523 is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
