Budget Builds: What junkyard parts will fit an XJ? - Page 23 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Budget Builds: What junkyard parts will fit an XJ?
Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-06-2011, 12:42 AM   #331
90jeepLaredo
1990 XJ Cherokee
is there anything else for the motor to make more power.
90jeepLaredo is offline   Reply With Quote
Unread 03-06-2011, 01:05 AM   #332
DoctorTim
previously XJ-Tim
DoctorTim's Avatar
if you want good power go with a diesel motor, your old 4.0 is going to experience more wear if you ask it for more power.
DoctorTim is online now   Reply With Quote
Unread 03-06-2011, 06:54 AM   #333
graxirena
1991 XJ Cherokee
Thanks SG, thats what I was wondering, cus ive seen the body lines on both models and the older one are a little bit sharper...maybe changing the fender would b good....but then what u do with the quarter panel??
So, the interior panels are not that friendly either with the 91 model on the glove box either?? bummer..Now, whats the door card???
graxirena is offline   Reply With Quote
Unread 03-06-2011, 07:50 AM   #334
sg_halvorsen
1994 XJ Cherokee
The door card is interior of the door. (arm rest, switches, etc) The lines aren't that off to really have it be bad with the quarter. Plus the only way to change that is to cut it out and weld a different one in and doing the quarter will lead to the taillights and then the rear hatch (if you give a mouse a cookie right?). For the fender to fit right you need to do the header panel also. You can get away with out doing it but you have to drill new holes for bolts and again the body line is round on the newer models and sharp on the older model.
Easiest way would be to switch just the doors out. There are a few right ups around here including one that was featured in JP magazine if I am not mistaken. That one shows how to fix the glove box hitting the arm rest (I think).
sg_halvorsen is offline   Reply With Quote
Unread 03-07-2011, 05:44 AM   #335
graxirena
1991 XJ Cherokee
bah...too much work for a 91...thank u SG!
Unread 03-07-2011, 09:34 PM   #336
sg_halvorsen
1994 XJ Cherokee
It's not that bad. Does sound like a lot of work but it can be done pretty easily. Depends on why you are doing it. If you are just replacing it I'm sure you could find an older model door. If you want the full windows, larger mirrors (which bolt to older doors), and better security then do it!
Unread 03-07-2011, 10:22 PM   #337
DoctorTim
previously XJ-Tim
DoctorTim's Avatar
Ok so i have installed the JK shocks on my XJ.
Fronts: Only need to replace the JK bar pins with the XJ bar pins.
Rears: Only need to press out steel sleeve. keep the JK bar pin.
I DIDNT BREAK THE DAMN SHOCK BOLTS!!!!!!
This is what i did; I knew i was eventually going to lift my XJ when i got it. so even before i got the parts for my lift, i (weekly) drenched the shock mount bolts with PB blaster at least four months before i even tried to remove the bolts. I recently was at the junk yard, tried to see how easy it really was to break those bolts, some snapped off even before i even really tried, so i think its safe to say that at least a month prior to installing your lift, you are REQUIRED to douse the bolts in PB blaster.
I noticed how it said that there is some dispute wether the JK shocks really do work. well they do and i can take pics for proof if you want lol.
Unread 03-08-2011, 05:17 AM   #338
Bandit1
Of course we want pics .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..
Here's Your Sign!!!!!!
2000 Jeep Cherokee Sport...Project Beast- Stock height , winch, recovery gear, roof basket, and a few other mods...
Outlawed Offroad Forums
NY State ORV Park Project
Bandit1 is offline   Reply With Quote
Unread 03-08-2011, 09:59 AM   #339
1slowhatch
1991 XJ Cherokee
newer 4.0 style intake manifold swap.
1slowhatch is offline   Reply With Quote
Unread 03-09-2011, 08:32 AM   #340
graxirena
1991 XJ Cherokee
so, you can swap the springs from a Wrangler and put them into a Cherokee and it will lift it up?
Unread 03-09-2011, 08:37 AM   #341
jetboy287
No it will drop it about 1"
jetboy287 is offline   Reply With Quote
Unread 03-12-2011, 09:53 AM   #342
Moshspeso
Will any of upgrades like 5.0 injectors work for a 94 ZJ W/ 4.0
Moshspeso is offline   Reply With Quote
Unread 03-12-2011, 12:38 PM   #343
keepishop
1989 XJ Cherokee
Yes, they will work. Same engine as 91-95 XJ.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Unread 03-12-2011, 02:12 PM   #344
Moshspeso
Thanks
Unread 03-19-2011, 10:29 AM   #345
grainofsalt
Budget dynomat, Go to lowes and pick up two rolls of pella door and window peel and stick membrane. Two rolls does two layers. I noticed a drop in the road noise level. Just remember to prime the rust first...
For sale: ZJ disc brake backing plates, Skid plates from a '85 blazer/S10. Make offer.
grainofsalt is offline   Reply With Quote
