Budget Builds: What junkyard parts will fit an XJ? - Page 2 - JeepForum.com
 6Likes
post #16 of 709 Old 08-30-2009, 12:14 AM
ep191
Swap in WJ knuckles/rotors/calipers/tie rod/drag link(i think that's it) for a good steering and brake upgrade.
The WJ knuckles use a crossover steering setup which is much nicer than the common Y-setups or inverted-t setups. I believe you can use the factory drag link and tie rod, or a better idea would be to make your own 1-ton steering setup.
The WJ brakes are also much larger.
ep191 is offline
post #17 of 709 Old 08-30-2009, 04:43 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The 99-up intake manifold was redesigned to have a better flow rate, and it is good for a few horsepower to swap it out if you have an older model. The mustang injectors are an upgrade as well. As far as I know they are a direct swap and instead of having a single hole, they have four holes for a better spray pattern.
Thawolff likes this.
xjfever is offline
post #18 of 709 Old 08-31-2009, 07:24 AM Thread Starter
RedZeppelinXJ
ok so here is a quick re-cap to any new post readers
Confirmed:
ZJ front coils = net only about 1 inch lift
S10 packs (cut eyes off main & bolt springs to XJ main) = 3-4" lift
JK shocks = slight mod to fit 2-4" lift
WJ brake booster & master cylinder = stop faster
YJ brake lines = bolt in & 3-4" longer
ZJ shift knob = replaces XJ knob
'97+ Ford 8.8" rear (need new spring perches, shock & track bar mounts) = 4.10 gears, LSD, disc brakes
Newer Intakes (with modification)
V8 ZJ Tierods = stronger than I6
WJ Knuckles/tierods/draglink (steering upgrade....gives you crossover steering)
WJ Rotors/Calipers = biggers brakes and more stopping power
Mustang 5.0 Injectors = bolt in and have 4 holes instead of 1 for more fuel and better spray pattern
Rumored:
ZJ alternators
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #19 of 709 Old 08-31-2009, 10:22 AM
ashylarry
the alternator will take some grinding to make it fit. I was just researching them today.
2000 XJ - 6.5" - IRO Long Arm - 4.56 Gears - ARB's - Superior Front & Yukon Rear Axles - IRO OTK Steering - Siped 35" KM2's
ashylarry is offline
post #20 of 709 Old 08-31-2009, 10:36 AM
ep191
just so you know, not ALL explorer 8.8's have 4.10's and LSD, you will have to do some searching for those
ep191 is offline
post #21 of 709 Old 08-31-2009, 11:02 AM Thread Starter
RedZeppelinXJ
V8 or I6 ZJ alternator?
post #22 of 709 Old 08-31-2009, 11:03 AM Thread Starter
RedZeppelinXJ
any give-aways as to which ones have 4.10's and LSD? Engine options? Trim packages?
post #23 of 709 Old 08-31-2009, 11:23 AM
ep191
I'm not sure as to which engine or trim packages have which, that probably isn't a great thing to rely on either.
If it were me I would probably just pop the cover off and take a look. LSD will be easy to spot over open spider gears. To check the ratio you can check the number of teeth on the ring gear and pinon gear.
# of ring gear teeth divided by number of pinion gear teeth = gear ratio
8.8 LSD
OPEN SPIDERS
I did a search and this should help you out. Look at the first 4 posts.
http://www.jeepforum.com/forum/f27/f...cation-227000/
ep191 is offline
post #24 of 709 Old 08-31-2009, 08:36 PM
ashylarry
V8 ZJ for alt is what I found
post #25 of 709 Old 08-31-2009, 09:54 PM
natertots
1990 XJ Cherokee
Dont forget the durango steering box on that list!
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #26 of 709 Old 09-02-2009, 07:45 PM Thread Starter
RedZeppelinXJ
Here is the latest re-cap of what we have found:
Confirmed:
ZJ V8 front coils = net only about 1 inch lift
S10 rear leaf packs (cut eyes off main & bolt springs to XJ main) = 3-4" lift
Durango steering box
ZJ V8 alternator (some grinding required) = more power for those of us with lots of accesories
post #27 of 709 Old 09-02-2009, 07:47 PM Thread Starter
RedZeppelinXJ
PLEASE ADD MORE STUFF GUYS......even if it requires some mild fab it should be on here! this is a great list for new jeepers and budget builders! Also post links to build threads using these mods you are listing if you want.
post #28 of 709 Old 09-02-2009, 07:53 PM
USMC_XJ
2003 WJ
Here is the link to the zj alternator upgrade: BC4x4.COM four wheel drive, 4x4, offroad and fourwheeling site.
Stock Cherokee alternator is 90 AMPS. The upgrade is 136 AMPS.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #29 of 709 Old 09-03-2009, 07:24 AM Thread Starter
RedZeppelinXJ
question to all you jeepers for the good of the order:
are nv3550's, TJ 6speeds, AX-15's, and BA 10/5's all bolt in replacements for eachother? are some of them bolt in replacements for others? what fab is required to make them work?
post #30 of 709 Old 09-03-2009, 07:50 AM
99Greenmachine
The input/output spline count can vary IIRC...
Some are a little longer/shorter than the others.
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
