Budget Builds: What junkyard parts will fit an XJ? - Page 16 - JeepForum.com
 6Likes
post #226 of 709 Old 08-12-2010, 03:08 AM
tucan69
1990 XJ Cherokee
i have seen alot of hype on front coils frint a f150 or bronco and im curious what years work, 2wd or 4wd either one higher than the other ? ive been looking already went and bought some rear s10 springs gonna dig into that totomarrow got them off a for 20 bucks from a guy a few towns over for the set
tucan69 is offline
post #227 of 709 Old 08-12-2010, 07:26 AM
portcityXJ
1995 XJ Cherokee
F150 coils are STIFF. Aftermarket coils are cheap, buy those.
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #228 of 709 Old 08-12-2010, 08:09 AM
bigbike
1995 XJ Cherokee
Dont know if this was posted but, 01-04 V8 WJ power steering pump, bolts in to 96?+ XJs. All you need to do is plug a return hole, and toss a xj pulley on. I can turn the wheel from the outside with one finger and ive blown the pump out before.
bigbike is offline
post #229 of 709 Old 08-14-2010, 01:32 AM
talentjeep
1987 XJ Cherokee
This?
Liberty KJ rear disc brakes to Cherokee XJ 8.25" Conversion - Jeep Cherokee Forum
Most of the pics still work as of now.
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
post #230 of 709 Old 08-16-2010, 01:53 PM
keepishop
1989 XJ Cherokee
V8 ZJ swaybar.
V8 ZJ Swaybar onto an XJ/MJ - Jeep Cherokee Forum
Also, will WJ swaybar links fit? They have a horizontal bushing at the top rather than a threaded vertical stud, so link extensions and such would be easier. They look like skyjacker links, but shorter.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #231 of 709 Old 08-30-2010, 11:27 AM
AniWahYaXJ
any specific years on the dodge ram van brake lines?
Do you have wooden long arms?... Yes...
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
AniWahYaXJ is offline
post #232 of 709 Old 08-31-2010, 12:08 AM Thread Starter
RedZeppelinXJ
hey guys i just did a quick update in the list on page 1......lemme know if there is anything you dont see there and lets keep this thread going.....feel free to post up links of builds/how-to's about these mods
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #233 of 709 Old 08-31-2010, 12:28 AM
motorsports3
1997 XJ Cherokee
Awesome thread. I have a lot of reading to do!
motorsports3 is offline
post #234 of 709 Old 09-05-2010, 10:00 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
JK Rear upper control arms can be used as longer LCA's on an XJ
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #235 of 709 Old 09-07-2010, 09:26 PM
grainofsalt
SFRautomotive, How much longer are the JK rear UCA's than XJ LCA's?
grainofsalt is offline
post #236 of 709 Old 09-07-2010, 09:54 PM
JEEPSFORUS
1997 XJ Cherokee
yea i love this post. big money saver.
JEEPSFORUS is offline
post #237 of 709 Old 09-10-2010, 10:27 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
i think its around an inch longer....ill have to measure
2013 COTY
post #238 of 709 Old 09-16-2010, 07:56 PM
Bandit1
Originally Posted by JV82000 View Post
Regarding the durango steering box. I read a post that they used the 99' durango v8. I did some research and found that the 98' and 99' durango 4x4 v6 and v8 use the same, 99' and 00' dakota 4x4 v6 and v8 use the same also.
I have also heard that there is a difference in the boxes between regular and one that was set up for a plow... I will try and find were i read it again and post back with link and differences
2000 Jeep Cherokee Sport...
- Stock height , winch, recovery gear, roof basket, and a few other mods...
Bandit1 is offline
post #239 of 709 Old 09-19-2010, 07:03 PM
AniWahYaXJ
i found a transfer case skid that will bolt right up off of an 87 cherokee wagoneer. also got a front skid off of a v8 zj that will fit with a little bit of imagination.
post #240 of 709 Old 09-20-2010, 01:11 PM
keepishop
1989 XJ Cherokee
From what I've seen the rotation is backwards. Probably set up for the pitman arm to be in the other direction.
Bleed or Quit.
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 03:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 07:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 06:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 02:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 09:27 PM
