Budget Builds: What junkyard parts will fit an XJ? - Page 11 - JeepForum.com
 6Likes
post #151 of 709 Old 12-03-2009, 05:37 AM
magnumcherokee
1992 XJ Cherokee
I see you can use JK shocks with a slight mod for 3-4" of lift , what is "slight Mod" ? Also I am concidering using the WJ front lower control arms, What grinding is needed? Is it grinding the bushing collars to fit in the brackets or the arms themselves for clearance on the axle brackets? THANKS!!
Again this is an awesome thread!!!!
92 XJ sport 4.0L HO auto 231 Rustys 4.5"(gained 5") SA lift, ROR Adj TB, AR23 wheels, 33x12.50 MT Baja MTZs, doorless when sun shining
magnumcherokee is offline
post #152 of 709 Old 12-03-2009, 06:31 AM
talentjeep
1987 XJ Cherokee
I used '93 Blazer leaf springs by cutting the eyes off the pack, taking out the spring with the alignment brackets on the ends and putting the whole thing with the thin metal spacers under my Jeep mainspring. I got 5" of lift total - 4" of lift over stock.
It did cause my axle to pitch forward a few degrees - I would suggest getting shims if anyone tries this again. I think I will be.
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
post #153 of 709 Old 12-03-2009, 07:37 AM
BRad704
Nothing to see here...
BRad704's Avatar
^^ 4x2 or 4x4 Blazer? Or does it matter? And how does that ride as far as stiffness?
BRad704 is offline
post #154 of 709 Old 12-03-2009, 09:47 AM
justanotherjpr
This has been covered many times using the S10 pickup 'bastard pack'
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #155 of 709 Old 12-03-2009, 10:10 AM
GunnerT23
I dont think anyone has covered these, Ut oveahead consoles and wodgrain center trim pices. they usually let those go pretty cheap and they are simple to install.
ya get a second trip computer
out side temp
nsew direction
DTE
current MPG
average MPG
better inside lighting
and extra storage
you need the console, wire harness, bracket that is poprivited, and temp sensor that goes behind the frnt bumper
GunnerT23 is offline
post #156 of 709 Old 12-03-2009, 01:29 PM
talentjeep
1987 XJ Cherokee
I like the ride. It's a little stiff but it really holds up well when cornering, especially without my sway bar.
I didn't think it was a 4x4 but I didn't investigate very close, I will next time I'm at the JY.
As for the guy who says this has already been covered I have not seen any mention of Blazer springs by anyone. Maybe the S-10 and the Blazer have the same exact springs? It would seem weird to me since one is a truck and the other is an SUV.
This thread is about what works from JY. Yeah S-10 springs work, now I'm saying Blazer ones do too.
post #157 of 709 Old 12-03-2009, 01:58 PM
oderalxjlaredo
I think they're based on the same platform, a la cherokee and comanche.
oderalxjlaredo is offline
post #158 of 709 Old 12-03-2009, 02:04 PM Thread Starter
RedZeppelinXJ
i think you are right but that doesnt mean they have the same rear spings, MJ's have spring under axle leafs that are longer than the XJ spring over axle leafs, but then again they may be the same, i'm not a chevy guy so idk, we got fords and jeeps around my place.
i will add the blazer leafs to the list thanks guys!
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #159 of 709 Old 12-03-2009, 03:03 PM
Kettles
the s10 and the blazer use the same frame. Whereas the Comanche and Cherokee don't. from the cab back the Comanche is totally different than the Cherokee, hence the differences.
And everytime I ever read a bastard pack people usually write s10/blazer springs.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #160 of 709 Old 12-03-2009, 03:40 PM Thread Starter
RedZeppelinXJ
i just checked it out he used full size blazer springs, not S10 blazer springs, i'm surprised they actually worked
post #161 of 709 Old 12-03-2009, 03:44 PM
Kettles
any 2.5" wide leafspring will work after you cut them... But some just would lift it more/be stiffer than others.
_=====o000o
Kettles is offline
post #162 of 709 Old 12-03-2009, 07:31 PM
talentjeep
1987 XJ Cherokee
It was a full size Blazer, yes.
I didn't know they made an S-10 Blazer....now I can see why you said it was redundant.
post #163 of 709 Old 12-04-2009, 11:42 AM Thread Starter
RedZeppelinXJ
its all good dude thats for the tip i never would have thought the full size springs would work....i wonder if they are any stiffer than the S10 Blazer springs
post #164 of 709 Old 12-04-2009, 02:54 PM
talentjeep
1987 XJ Cherokee
I wish I had a way to gauge it better.
I really like stability and I have a heavy foot often enough that soft springs just don't work for me. I've seen a little improvement in MPG I think - but I've still got another 1/2 a tank to go before I know.
The only "4x4ing" I've done with it is some light mud/hill stuff in my work's back lot. I hope I don't get a ticket but me and the store manager's kid just love burning doughnuts! I've found the wheels keep better contact with the ground and it has less body roll. I lose a little traction from the lack of flex sometimes but overall I've gained traction.
I've considered throwing 300-400lb of sandbags in the back to really break the springs in...and I need to shim to get the angle right. Thankfully I can be lazy since I have a long collar supporting my driveshaft!
post #165 of 709 Old 12-05-2009, 07:27 PM
natertots
1990 XJ Cherokee
Here ya go! http://www.jeepforum.com/forum/f11/i...ite-up-603221/
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
Budget Builds Recap with Links Blazin Den XJ Cherokee Technical Forum 13 12-04-2015 02:52 PM
junkyard parts run gregamuffin XJ Cherokee Technical Forum 5 03-20-2009 06:01 PM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
Budget junkyard upgrades Double_D XJ Cherokee Technical Forum 18 04-14-2008 01:04 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
