Budget Builds Recap with Links - JeepForum.com
post #1 of 14 Old 09-09-2009, 08:02 PM Thread Starter
Blazin Den
I have read through the Budget Builds: What junkyard parts will fit an XJ? post and have used Zeppelin recap list, well most of it, and searched for what I thought was the best links for each one. You guys can add links later but heres the best ones that I came up with:
Suspension & Lift:
1. ZJ V8 Upcountry Coils = 1-1.5" lift
http://www.rocklizardfabrications.co...dget_boost.htm
ZJ coils on an XJ - Jeep Cherokee Forum
http://www.pirate4x4.com/forum/showthread.php?t=595075
2. F-150/Bronco Coils ('79-ish) = 4-4.5" lift
Jeep Cherokee Suspension - XJ Budget Lift - "How-To" Lift Your Jeep Cherokee XJ 4" on a Budget
3. S10 leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift
S10 Springs "Bastard Pack" - Jeep Cherokee Forum
$11 Bastard Leaf Pack Writeup. *Tons of pics* - NAXJA Forums -::- North American XJ Association
FitchVA’s Jeep Page » Writeups » Home-Brew 2″ Budget Boost (BBB)
4. Dakota Leaf Springs
Brakes:
1. Xj Brake Booster Upgrade Pre 96
MADXJ go to the brake section
2. WJ Brake Upgrades
XJ Cherokee Conversion to WJ Front Brakes & Steering
WJ Grand Cherokee Master Cylinder and Booster Upgrade How-To - Jeep Cherokee Forum
3. YJ Brake Lines = 3-4" longer
4. WJ Rotors/Calipers = bigger brakes and more stopping power
Jeeps "R" Us - Have you climbed a rock today?
Axles:
1. Ford 8.8 inch ('97+) = need spring & shock mounts (4.10, LSD, Disc Brakes)
Ford 8.8 Axle in YJ (for a YJ but same concept applies)
BC4x4.COM four wheel drive, 4x4, offroad and fourwheeling site. ( xj version)
Front End & Steering:
1. ZJ V8 Tierods = beefier & bolt in
ZJ Tie Rod Upgrade - Jeep Cherokee Forum
http://www.jeephorizons.com/tech/tjtierod/
http://members.rennlist.com/gman/jeep/
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering
3. Durango Steering Box = beefier
Durango Steering Box Upgrade - Jeep Cherokee Forum
4. WJ LCA's = more tire clearance (some grinding required)
WJ Lower Control Arms in an XJ - site under construction 10/2013
WJ control arms into XJ - missing pics
WJ control arms for an XJ?
WJ control arms to XJ? - NAXJA
5. ZJ pitman arm = 1 inch drop over stock
ZJ Steering - NAXJA Forums -::- North American XJ Association
Do I need a drop pitman arm?? - Jeep Cherokee Forum
Engine Performance:
1. Newer XJ intakes (may require some modification)
4.0L 99+ intake manifold swap with REAL DYNO NUMBERS! - MallCrawlin.com Forums
Swapping to a 2000 Inlet Manifold
2. Mustang 5.0 Injectors = bolt in (have 4 holes instead of 1, more fuel, better spray)
http://www.jeepforum.com/forum/f11/m...ectors-666038/
3. ZJ V8 alternator = more power to run accessories (some grinding required)
alternator upgrade? - Jeep Cherokee Forum
alternator swap - NAXJA Forums -::- North American XJ Association
4. Taurus Dual Electric Fans ('96-98) = replaces mechanical fan, better cooling
Taurus Fan Install
Other:
1. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing)
The AX-5 to AX-15 Swap Thread - NAXJA Forums -::- North American XJ Association
2. Lebaron or laser hood vents = help keep ur 4.0 cool
http://www.jeepforum.com/forum/f11/h...w-pics-472815/
3. 97+ Door Swap on older models
Jeep Cherokee XJ Door Upgrade - Jp Magazine
4. MJ Bucket seats = tilt forward, bolt in to at least older XJ's
http://www.jeepforum.com/forum/f53/w...manche-460083/
5. ZJ gas tank skid = can be modified to fit 97+
XJ Gas Tank Skid Plate Install
This is by no means the only links that i found but ones that have pictures and mabe better descriptions to help out others who are trying to do the same thing. If you guys want to add to the list you can but put up links to what you find.
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #2 of 14 Old 09-12-2009, 07:30 PM
USMC_XJ
2003 WJ
Excellent job!!
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 14 Old 09-12-2009, 11:30 PM
xjdude42
1989 XJ Cherokee
Awesome! Maybe this needs to be in the FAQ?
xjdude42 is offline
post #4 of 14 Old 09-14-2009, 06:25 PM Thread Starter
Blazin Den
i edited it and added some other links
post #5 of 14 Old 09-21-2009, 09:44 PM
BayouBengal85
awesome list, added to book marks. was on the fence about doing the brake upgrades, but with walkthroughs that detailed, i will definitely be locating parts to do this in the near future. thanks a million!
96 2wd XJ Sport, 4dr, 4.0HO, Auto, 3.55 gears,117k Miles
15x8 Canyon Rims
31x10.50x15 TreadWright Warden AT's
Fram Air Hog Filter
Magnaflow Hi Flow Catalytic Converter
Dynomax Superturbo Catback Exhaust
BayouBengal85 is offline
post #6 of 14 Old 10-31-2009, 09:17 AM
g33p
KILLER thread! Bookmarked!
g33p is offline
post #7 of 14 Old 06-13-2010, 06:27 AM
cbenez1
Thanks for alot of useful info yet again
cbenez1 is offline
post #8 of 14 Old 07-15-2010, 10:58 PM
jbhoss1970
1989 FSJ Wagoneer
Thanks for doing the legwork... awesome resource
jbhoss1970 is offline
post #9 of 14 Old 09-29-2013, 02:00 PM
PeteNnewburg
Please repair the links
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #10 of 14 Old 09-30-2013, 08:39 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I added some additional links to the 'WJ control arm to XJ' discussion in the original post here since the MadXJ site currently returns an "Under Construction' error.
The original discussion that this thread summarizes is here. > Budget Builds - What junkyard parts will fit an XJ
There may be additional information posted there since this thread last saw a comprehensive update.
***Chris***
chris87xj is online now
post #11 of 14 Old 09-30-2013, 06:21 PM
PeteNnewburg
Links
Thank You Chris!!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #12 of 14 Old 10-19-2013, 09:26 PM
lonnienfg
I may have missed it but, did anyone talk about using stock TJ Front Sway Bar links for 3" to 4" of lift? Just finished mine today, 4" (from extremely sagged stock)and the TJ links are perfect!
Sent from my GalaxyS4 using JeepForum
lonnienfg is offline
post #13 of 14 Old 10-23-2013, 06:07 AM
stoobb
Hi there.
Can a 1998 manual, GC Limited 2.5TD fuel pump be replaced with a fuel pump from another engine from the Chrysler family? I live in KSA and parts for 1998 diesel Jeeps are non-existent. Any help appreciated. Thanks.
stoobb is offline
post #14 of 14 Old 12-04-2015, 02:52 PM
RacerX
1989 XJ Cherokee
Xj
Question on:
Suspension & Lift:
I can't find "Upcountry" listed at either NAPA or O'Reilly's in their Grand Cherokees (I tried 1994 as a good year for a ZJ)
http://www.oreillyauto.com/site/c/se...1994&make=Jeep
http://www.napaonline.com/Catalog/Ca...359_0162320288
--- Anyone?
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline
Budget Builds: What junkyard parts will fit an XJ? RedZeppelinXJ XJ Cherokee Technical Forum 708 06-20-2016 04:20 PM
Budget lift for budget wheeler budgetHERO XJ Cherokee Technical Forum 5 02-27-2009 01:06 PM
where is the guy who builds custom roof racks thread?? beaucaldwell XJ Cherokee Technical Forum 0 02-05-2009 12:11 AM
bumper websites or builds? mattiek XJ Cherokee Technical Forum 2 03-09-2008 05:15 PM
fullsize builds mud-dog27 XJ Cherokee Technical Forum 3 11-01-2006 05:56 AM
