Bucking, Dying and Not Starting - JeepForum.com
post #1 of 5 Old 09-13-2013, 05:22 AM Thread Starter
NOTAMs79
Howdy all. I have a bit of a quandary here on my 2000 XJ, 170Kmiles.
Yesterday as I was slowly driving through a parking lot the jeep just died. (Reminded me of a crank position sensor that went bad on me years ago, no warning, just nothing.) The jeep did start right back up though. An hour later I'm doing 70mph down the highway and the jeep begins to buck (almost felt mechanical). Slowing down eliminated the bucking. When I say "bucking"I mean bucking! I thought the jeep was going to tear apart. Also, the bucking at those speeds is intermittent. Everything's great for 5 minutes then wham! Now this morning the jeep wouldn't start, initially. The engine turned over strongly. On about the fifth attempt to start it she roared to life. That's it, thoughts? I appreciate any information you may be able to lend.
NOTAMs79 is offline
post #2 of 5 Old 09-13-2013, 05:33 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Have you seen a check engine light? If so, gotta pull the codes for clues/guidance.
If you don't have a CEL, I'd start by first ensuring you have fresh spark plugs (I like NGK copper plugs gapped to .035 for your vintage) and testing your fuel pressure.
For your 00, you should have 49 psi at idle. If you don't have access to a fuel pressure gauge, they can be rented from many parts stores; call around.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #3 of 5 Old 09-13-2013, 05:43 AM Thread Starter
NOTAMs79
Thanks for the reply. I should have mentioned, no CEL. I wish it was that easy. I'll call around for a pressure tester. Did I mention that I have a 130 mile trip back home today?....I just hope I can limp it along.
NOTAMs79 is offline
post #4 of 5 Old 09-13-2013, 11:39 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Based on the limited info, I would guess CPS, O2 sensors, or TPS as the cause. They all can be easily tested for proper functioning.
CJ7-Tim is offline
post #5 of 5 Old 09-13-2013, 12:47 PM Thread Starter
NOTAMs79
I think it's the CPS! The night before these things started happening my fuel gauge was reading much lower than actual then it went back to normal the next day. If this is a symptom of a bad CPS, as noted in another thread, and it died like it did the last time the CPS went bad I can't believe they're not correlated.
NOTAMs79 is offline
