Brown dog engine brackets necessary? - JeepForum.com
post #1 of 16 Old 03-25-2013, 09:14 PM Thread Starter
jackdup
I'm planning on getting a set of brown dog rubber motor mounts but am trying to decide if the beefy engine brackets are worth the extra money or not. My understanding is the stock engine brackets are cast and can break causing a lot of damage when the engine drops. How commonly does this really happen? I'm not always the easiest on my xj. I play in the rocks a lot and I like the skinny pedal. What are your thought? Thanks!
jackdup is offline
post #2 of 16 Old 03-26-2013, 03:15 AM
Timo_90xj
Timo_90xj's Avatar
If you've got a heavy foot and play on the rocks, I'd highly recommend sturdier engine mounts than the stock ones. It's not the engine mounts that break, but the mounts get sheared off the block causing damage (that is, engine block suffers the damage). Brown dog mounts use a lot more mounting holes and spread the load over larger area preventing carnage.
IMO the mounts are overpriced, it'd be fairly easy to fab 'em if you have a welder. However, it's a fairly small price to pay compared to a worst- case scenario.
***Under construction***
Timo_90xj is online now
post #3 of 16 Old 03-26-2013, 07:26 AM
biffgnar
biffgnar's Avatar
Another option for good motor mount brackets is Stinky Fab Racing. I bought a set from them when at KOH last year. IIRC same price ballpark as Brown Dog so maybe not a helpful suggestion.
Romney in 2020!
biffgnar is offline
post #4 of 16 Old 03-26-2013, 03:32 PM
foggybottombob
The rubber tears out of the stock mounts. Brown Dog rubber mounts make your rig vibrate at idle. I have them.
foggybottombob is offline
post #5 of 16 Old 03-26-2013, 04:08 PM
biffgnar
biffgnar's Avatar
He's talking about the brackets not the rubber mounts.
Romney in 2020!
biffgnar is offline
post #6 of 16 Old 05-15-2013, 03:43 PM
BerTJ
My stock 3 bolts ripped right out of the Engine Block. If I were on the trail it could have been a PITA! Its not a bad idea to upgrade while your in there!
BerTJ is offline
post #7 of 16 Old 05-16-2013, 07:45 AM
Paradise XJ
1988 MJ Comanche
Sorry, I don't understand how this could occur, just driving along. Maybe if the integrity of the bracket was compromised due to rust etc. Had the Jeep had some traumatic event? Were they loose? Rusty? Had the bracket been removed, engine swapped?
The brackets on my MJ are original, as are the stock mounts. When I replace the mounts last weekend, they were toast, but the brackets were rock solid.
Like said above, if you push the Jeep hard and climb around in the rocks, you're better off with beefed up brackets AND mounts
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #8 of 16 Old 05-16-2013, 07:47 AM
cj7allday
2008 TJ Wrangler
go with ALOT sturdier ones
cj7allday is offline
post #9 of 16 Old 05-17-2013, 09:54 AM
BerTJ
The Stock Brackets were fine but only use 3 bolts to the block. These Brown Dog brackets utilize 7 bolts on the driver and 8 on the passenger. Sometimes just a speed bump and the block will give way and your bolts rip right out.
BerTJ is offline
post #10 of 16 Old 05-17-2013, 09:20 PM
NHJeep4x4
1987 YJ Wrangler
I recommend replacing the stock ones; I've broken the passenger side bracket twice (replaced the first one with a junkyard unit). The motor rolled to the side and took out the distributor. I was just driving down a dirt road, not even wheeling. The second time, it broke just getting into the trail. I threw a log over the engine bay and held up the motor with a ratchet strap and it got me the 3 miles home. Neither of them sheared the bolts, but just broke in half.
Now I have Brown Dog brackets on both sides. If not Brown Dog, at least get something better than stock.
I guess they added a lot more bolt holes since I bought mine.
Old:
2.5L, 31s
NHJeep4x4 is offline
post #11 of 16 Old 05-18-2013, 06:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's what usually happens. Seemed to be most prevalent in the early HOs.
From Jon Kelley aka 5-90 @ www.kelleyswip.com
This is a known issue.
1) Unless you're going to get silly with the skinny pedal, 2xSAE8 screws on one side won't be a huge problem. You'd be better off with three, but if you don't get silly you'll be okeh.
2) The Brown Dog engine mounts use two or three additional holes on each side, and spread the mount/clamping force over more of the block. This is invariably a good idea, and I'll probably be doing it as I refit my 88.
3) The primary reason that the screws snap is because, sometimes, the screw holes in the block aren't drilled & tapped deeply enough. This causes the screw to bottom out in the hole, so you end up torquing against the bottom of the hole instead of stretching the screw (as you're supposed to do. Not your fault - you aren't doing anything wrong.) The screw is not stretched properly, and the head is not butted up against the bracket, so there's some room to move there. Vibration then causes wear cycles on the screw, which generally leads to rupture.
The easy/cheap fix? When you replace the screws (3/8"-16x1.25", as I recall,) put two flat washers under the head before you screw it into the hole.
The check? Take a feeler gage (.003" to .005") and try to slide it under the head of the screw. You'll be able to get under the corners (look at the hex head, and you'll see that the surfaces curve toward each other slightly) if it's a standard hex head - if it's a flanged hex head, you should not be able to get under the head anywhere. If you can slip the gage under the head, you have a problem. If you can touch the shank of the screw, you have a big problem!
In no case should you reuse the screws after you take them out - they'll be stressed under the head, and you'll have a significant reduction in strength. Replace them outright, putting washers under the head as I mentioned before. The washers will make up for the slight lack of depth in the hole (two of them will be about 0.125" or so,) and allow the screw to be preloaded properly.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #12 of 16 Old 05-21-2013, 07:07 AM
bpvideo
1995 XJ Cherokee
I have a 95 2dr stock 4.0, about to have to replace the exhaust manifold that is cracked. I have a "rough" idle or at least a vibration at idle and engine does shake a bit, how can I tell if my engine mounts are bad? They visibly seem ok, but not a lot you can see on these. I am not doing any off roading at this is just a 2wd. But I have heard the horror stories and do not want to have to replace the header I am about to put on.... any help on diagnosing or testing the motor mounts?
bpvideo is offline
post #13 of 16 Old 06-06-2013, 05:33 AM
NHJeep4x4
1987 YJ Wrangler
I've noticed that the stock motor mounts wear out when the rubber disintegrates. This will not cause the motor to flop over, as it's still supported, just not by the rubber anymore. The horror stories are from when the engine bracket fails (either the bolts break or the bracket itself). I would think the only ways to check the engine brackets are to check the bolts or for any cracks in the bracket.
Maybe to test the motor mounts, you could jack up the motor a bit to see if there is significant play in the mounts.
Also, Brown Dog has great customer service!
Old:
2.5L, 31s
post #14 of 16 Old 06-06-2013, 05:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's what happens with the bolts. Easy enough to take care of BEFORE catastrophe strikes.
post #15 of 16 Old 06-07-2013, 05:14 AM
cdn_xj
I've returned to the fold
cdn_xj's Avatar
I have had this happen. Passenger side bolts holding the mount to the block sheared off. the engine rolled to the passenger side and was held up by the distributor resting on the mount. Fortunately the damage was limited to that. UNfortunately the issue was discovered the week before Christmas and no one had shop space or time to effect the repairs for me.
Soooo...The Friday night before Christmas about 3 years ago I stayed late after work and working only with some hand tools, a right angle drill, some stubby drill bits that I still had to cut down more, no engine hoist, and an air compressor that kept tripping the breaker I pulled an all-nighter and drilled out 3 bolt shafts that I could not see and replaced the 3 bolts. And it only took me 14-1/2 hours.
The issue: I could not raise or lower the engine enough to get clear access to the last bolt. The frame rail was in the way. Hence the use of a right angle drill and stubby bits that had to be cut down further. In retrospect, I cannot remember whether I unbolted the driver's side mount or not. either way, it took me something on the order of 5 hours to get at and drill out/easy out the first bolt. And for the record, easyouts, contrary to the name, are NOT that easy to get broken bolts out with under ideal conditions and damn near impossible under adverse conditions.
Upon inspection it appeared that 2 of the bolts had sheared off previously and I had been running on the remaining bolt for some time. until i hit a big pothole.
The ONLY thing that was positive about the whole ordeal was the fact that the broken bolts were Grade 5 and not Grade 8 otherwise it might have taken me the entire weekend.
So, in a nutshell, if you even THINK you need to ugrade to the BrownDog mounts (or similar), Do it.
'99 XJ Sport 4-dr
4.0 HO - AW4 - NP231 - D30, 4.10, Open - ChrysCo 8.25 29-Spline, 4.10, OEM Trac-Loc
Stock with a crapload of bolted on bits
cdn_xj is offline
