#1 | |
Broken shock bolt
so I was working on putting my new shocks in this afternoon and as I was turning one of the right rear top bolts I snapped the head right off. I was wondering if their is any way without drilling it to get it out? maybe pull out my carpet and turn it from the top? any ideas? this is my DD so i'm sunk as of now
#2 |
With the shock out of the way, you might be able to reach the upper end of the bolt and turn it by hand.
#3 |
there are a lot of threads about this. do a search and you will find out a lot about it.
#4 |
Very common problem happens to most of us jeepers
98 xj 4.0L 231 t\case off road commode 4 in the floor and a fifth under the seat Eat more possum |
#5 |
just punch it out from the bottom with an air hammer and feed a new bolt in from the top.
93 Jeep Cherokee Country 4.0 AW4 Flowmaster / APN header 3" mismatched lift 30" Bighorns on V5's Last edited by Scottmc01; 08-28-2008 at 08:33 AM.. |
#6 |
Scottmc01 is exactly right, Punch her out then run a new one from the top. Once you get it out, takes all of 5-10 min to finish it.
#7 |
Here is a post on how I did mine:
http://www.jeepforum.com/forum/f11/diy-no-worries-broken-upper-rear-shock-bolt-repair-556807/ |
#8 |
#9 |
When i replaced mine, all four HEADS snapped off, but i did my research, and found out that the numerous write-ups on this forum fit the application perfectly. With that being said, here is mine:
http://jeepforum.com/forum/showthread.php?t=557363 Good luck, its not that bad.
1999 XJ..... Stock, with some intake/exhaust work "The ol' family truckster" |
#10 |
1998 2door XJ - RE 3.5 SF and 2in teraflex shackle and spacers, 35x12.50 BFG M/T, 15x8 RockCrawler Wheels, AJ's offroad super rails, Nates 4x4 rear bumper, Flowmaster 40 Optima Yellow Top, Currie Enterprise HD Tierod and Draglink and lots of cut sheetmetal 1998 ZJ - daily driver |
#11 |
This just happened to mine last night. It was only one bolt though. We drilled it out and re tapped. Worked great.
"What I've want is what I've not got What I need is all around me" DMB |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
