Broken Oil Fill Cap? - JeepForum.com
post #1 of 21 Old 11-07-2010, 08:26 AM Thread Starter
UNHCLL
Has anyone ever had the Oil Fill cap break?
I have a '99 4.0L.
I was in the middle of doing an oil change on Friday, only to discover the oil cap won't come off. It feels like the inner "barbs" are broken/stripped so it won't lock when trying to turn it counter-clockwise for removal. It feels normal when turning clockwise.
I anticipate it will necessitate the removal of the valve cover now to get the cap out, without leaving parts inside the valvetrain?
Filling the engine with oil again through the dipstick tube was a slow and tedious process.
Thanks,
Chris
UNHCLL is offline
post #2 of 21 Old 11-07-2010, 09:15 AM
justanotherjpr
I have had this happen once on my wife's 2002 4.0L WJ. I'm a keyboard commando for a living, but not especially weak and I could not get this thing off with my hands.
I took a screwdriver and a hammer and gently knocked the handle counter clockwise (like I was backing it out) and the cap came free. It ended up breaking in two pieces, (the upper part that has the handle, and the inner part that screws into the cover) but the inner piece screwed out with my fingers. I just snapped the handle back in and re-installed it on my XJ, and put the one from my XJ on hers.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 21 Old 11-07-2010, 09:43 AM
alexrule123
alexrule123's Avatar
That happened on both of my XJs! Just turn the cap until the top part comes of, then you can use an adjustable wrench to turn it and remove the bottom part.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #4 of 21 Old 11-07-2010, 10:53 AM
TDTech
it happens all the time on the 4.0's. Bad design I guess. A new cap from the dealer is like 6-7 bucks.
TDTech is offline
post #5 of 21 Old 11-07-2010, 12:36 PM
Spencer43783
Yeah it's a junk 2 piece design. All of the 4.0Ls oil caps do that. The plastic on the insides get worn out and it gets stuck in there. They should have made it a 1 piece design instead of attempting the ratcheting 2 piece crap. Just pop the top of the cap off with a pair of pliers then get a big pair of pliers and grab the bottom portion of the cap and twist it off. You can snap it back together and put it back on or replace it. I grabbed one when I was at the JY so I could have a spare when mine started doing that.
1998 Cherokee Sport 4.0L-AW4-NP231-C8.25--Black, trim removed and chopped. 31" Goodyear Wrangler Duratracs. 3" lift coming soon.
1984 Grand Wagoneer--Sold. I'll miss the old girl.
Spencer43783 is offline
post #6 of 21 Old 11-07-2010, 01:04 PM Thread Starter
UNHCLL
Thanks for the input and resolutions!
I didn't want to just start smashing on it at 6pm on Friday night.
I'll order a new cap from WorldPac tomorrow.
Thanks again!
UNHCLL is offline
post #7 of 21 Old 11-07-2010, 06:23 PM
GregB_00XJ
Funny thing...mine just did this yesterday too? I sadly had just drained out all the oil, and popped up top to pull off the cap. All it did was freewheel... couldn't tighten or loosen. FAIL
I popped the top half of the cap off with a wide flat blade screwdriver and the inside of the top was shredded. Not sure how this happened as you cant over-tighten these, but it did. Bad design I guess? I used some channel locks to get the bottom half out, finished my oil change and went to the store this morning to get a replacement.
SO lame...I have never had this happen on any vehicle.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #8 of 21 Old 11-07-2010, 07:15 PM
jeepkid03
Winning
jeepkid03's Avatar
This happened once to mine but I was able to get it off. What you do is take the palm of your hand and press downward as hard as you possibly can on it while trying to turn it. Worked for me.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #9 of 21 Old 11-07-2010, 09:58 PM
GregB_00XJ
Tried that, once I got the top half off the ratchet (gears) on the inside were all mangled. It was a dead thing.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #10 of 21 Old 11-07-2010, 10:13 PM
99Greenmachine
Happened to mine, I went and grabbed one from a JY...all 4.0L caps will work haha
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #11 of 21 Old 11-07-2010, 10:21 PM
leadnbrass
I'm on my third on (I think) the top always separates (strips) from the bottom.
I gave up and just open it with a pair of channel locks now.
leadnbrass is offline
post #12 of 21 Old 11-07-2010, 10:26 PM
3vze28
i just remember from now on not to go insanely tight with my oil cap, cause mine does it too.
3vze28 is offline
post #13 of 21 Old 11-08-2010, 06:18 AM
rugsucka
I just use the bottom half and hand tighten it with a rubber palm glove on.
The first time it broke, after swearing a bit, I used a pair of vice grips to grab the lip and turn it open.
Until the other 30 things I need to do to my heap get done - some needed, some wanted - I will save that 5-10 bucks for something else.
rugsucka is offline
post #14 of 21 Old 11-08-2010, 06:30 AM
mikethefisher
pipe wrench works to get it off. be sure not to make it too tight or youll crack the plastic
mikethefisher is offline
post #15 of 21 Old 11-08-2010, 07:20 AM
shaman1204
X2. Has happened to me thrice in two months of ownership. Granted the last one was a cheapo from autozone. Channel locks work great.
shaman1204 is offline
Fill to spec or to Rockcrusher Fill Plug rc76 XJ Cherokee Technical Forum 14 10-09-2009 03:25 PM
broken front leaf bolt + broken nut beneharris XJ Cherokee Technical Forum 3 07-01-2009 12:01 AM
Heater switch half broken, Headlight switch completely broken. Halp! Jameslol XJ Cherokee Technical Forum 1 03-10-2009 08:43 AM
Takes a long time to fill up fuel tank (have to fill up slowly) TMXONR XJ Cherokee Technical Forum 12 11-09-2008 12:14 PM
pcv/breather issues...broken gasket/seal in front of oil fill. severous01 XJ Cherokee Technical Forum 4 09-10-2006 09:50 PM
