Quantcast Broken oil cap tip - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Broken oil cap tip
Old 08-14-2004, 01:17 PM   #1
okcjeeper
Broken oil cap tip
Alright, just though that I would pass this on real quick. We have all read the posts regarding the damn plastic oil cap that tends to break if "ratcheted" down. Well, I go to change my oil and sure enough, the teeth have been broken. So....when this occurs, I found the simplist way to remove the cap is to pop off the top and lay a thin piece of cloth material over the piece left in the filler hole. I then simply put the cap over this and tapped it back in place. The extra material offered a little more grab to the worn teeth and the cap screwed right off.
Anyways, just a quick tip. Later!
"Work Hard... those on welfare depend on you"
Stock 99XJ/4wd/NP242/Firestone Destination AT's/Surco Rack/Hella's/CB/3' Firestik/Factory Overhead Console Installed
okcjeeper is offline   Reply With Quote
Old 08-14-2004, 01:23 PM   #2
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Yeah the same thing happened my first oil change. I used some glue to prevent the thing from racheting, so far its been holding up well.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Glock Forum
