Broken Hood Release Cable - JeepForum.com
post #1 of 6 Old 03-05-2011, 08:50 AM Thread Starter
rapidcycler
Morning all,
Haven't been to this forum in a bit, but when I encountered a problem, I immediately thought of you guys/gals!
OK, 98 xj classic hood wouldnt' latch shut.. I ignored it until it flew up in to my windshield, but decided to ""fix it" this morning.. Solution was generous amounts of Liquid Wrench to the mechanism(kicks self repeatedly). Closed and stayed latched.. PROBLEM.. went to open the hood.. and cable had popped (prolly when hood flew up) and now I can't open my hood..
How do I open my hood with a broken hood release cable??? It broke right at the connection to the handle.
Thanks in advance.
Andy
rapidcycler is offline
post #2 of 6 Old 03-05-2011, 08:56 AM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Start taking the headlights and such out. Then remove the grill. You can reach up and get to the mechanism in the center. If that doesn't work, do each side individually.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #3 of 6 Old 03-05-2011, 09:00 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Before you disassemble anything, try unraveling a bit of the cable casing where the handle used to be. If you can expose any of the release wire, use a Vise Grips to grab the wire and pull.
A new or used hood latch cable is easy to install.
CJ7-Tim is offline
post #4 of 6 Old 03-05-2011, 09:22 AM Thread Starter
rapidcycler
ugh, I hope it doesn't come to that..but good approach if all esle fails.
post #5 of 6 Old 03-05-2011, 09:25 AM Thread Starter
rapidcycler
this is my first plan of attack... have to take some of the plastic inside molding off to get to it though.. not a big deal. Thanks for the heads up on the cable, I gotta be able to open my hood at will.
post #6 of 6 Old 03-05-2011, 09:52 AM Thread Starter
rapidcycler
Thank you! That worked like a champ! Removed that bit of side panelling, and took the mounting bracket off by removing three allen head screws (for easier maneuverability), then cut cable from it and started whittling it back til I got to wire. Pulled wire with pliers and hood popped right open.
Thanks for the quick and accurate response!
Andy
Hood Release cable broken... JeepDVL45 XJ Cherokee Technical Forum 5 12-28-2009 04:44 PM
XJ hood release cable miketyson XJ Cherokee Technical Forum 4 08-17-2008 04:50 PM
Hood release cable broken...any ideas to open hood? jeeps4life XJ Cherokee Technical Forum 6 05-16-2007 12:16 PM
Hood Release Cable Broken Sir Charles XJ Cherokee Technical Forum 8 12-22-2004 09:51 PM
hood release cable ilovjeep XJ Cherokee Technical Forum 3 09-28-2004 03:45 PM
