Brakes have no power and will not hold on inclines - JeepForum.com
post #1 of 8 Old 04-29-2013, 12:14 PM Thread Starter
Topgun514
1988 XJ Cherokee
I have been having an issue for a bit now but last time the mechanics had the jeep for a U joint replacement (I was lazy), they drove it around and said brakes felt ok. When I got my inspections this past september, I was told they were close to not stopping quickly enough but passed inspection still.
The issues have made me drive even safer, but I figure brakes and steering are the 2 most important safety features. So I was wondering if you guys could help diagnose possible issues. My brake experience is extremely limited.
Brakes will not lock up unless it is snowy and icy. The back lock up very easily when wet, winter was tricky to say the least when the brakes were even slightly wet. Stomping on the pedal will not lock them up on dry pavement.
POSSIBLE ISSUE: I am wondering if I have a vacuum or some leak. When I am on an incline, I have to keep my pedal pushing in, it will slowly lose power (over 30 seconds) and I step harder. When the pedal hits the floor I have to repump the brakes or hold onto the e-brake so I don't go into traffic.
1988 Renix all. Base model, no ABS.
Thanks in advance
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #2 of 8 Old 04-29-2013, 12:50 PM
00XJMikey
A worn out brake booster and bad fluid is what's causing me to have the same problems (not as bad brake fading).
IIRC, summitracing.com sells reman units for around $40 - $50.
00XJMikey is offline
post #3 of 8 Old 04-29-2013, 12:51 PM
Elias4WDCenter
Leaky line, brake cylinder or master cylinder.
Worn brakes.
You need to pull your wheels off and inspect your brakes. Also, follow the lines from the master cylinder to each wheel and look for wet spots.
If you cannot determine the condition of your brakes on your own yet, you need some friends that have done it before to help out, or get a professional brake job. Hopefully you can round up some buddies to help out and show you how to do it.
Be safe.
Sales, Service & Installation - Suspension, Accessories, Wheels and Tires, Recovery Gear, Bumpers. WE SET UP AXLES, GEARS and LOCKERS. (And we'll work on your mother-in-law's Honda so you can wrench on your Jeep!) 978-597-8432 Mon - Thurs, 8 a.m. to 6 p.m.
Townsend, MA. Tell us Jeep Forum sent you!
Elias4WDCenter is offline
post #4 of 8 Old 05-01-2013, 04:18 PM Thread Starter
Topgun514
1988 XJ Cherokee
I looked at my brake fluid, its dark alright but haven't lost a single drop. Looked around and didn't see any leaks.
Could this narrow down the results?
96 XJ Sport- Sold
post #5 of 8 Old 05-01-2013, 07:09 PM
Nick05
1994 XJ Cherokee
can you bleed them or have you done that?
Nick05 is offline
post #6 of 8 Old 05-01-2013, 07:36 PM
XJaySC
1975 CJ5
Take it to a trusted shop and have the brakes inspected.
Several things could cause the problem you have but with out putting my hands on it its all just guessing.
If you don't have any experience with brake work I wouldn't suggest bleeding the system.
XJaySC is offline
post #7 of 8 Old 05-02-2013, 08:59 AM Thread Starter
Topgun514
1988 XJ Cherokee
Ok thanks guys. I appreciate the responses. I think shop time is where it's, dreadfully, heading.
96 XJ Sport- Sold
post #8 of 8 Old 05-02-2013, 09:09 AM
jeepster383
If you're pedal is dropping and there's no visible leaks on the outside I would suspect the master cylinder
jeepster383 is offline
