Quantcast Brakes Dragging - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Brakes Dragging
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 11-07-2008, 09:13 AM   #1
djzero
Brakes Dragging
I just did my brakes this past weekend and since then I can tell at least one side is dragging pretty bad. I'm pretty sure it's the driver's side since it was hard to turn once I put everything back together. I noticed the cylinder in that caliper was pretty tough to put back in. I had to take the bleeder valve all the way out and even then I needed leverage to push it in, I couldn't do it with just my hands like the other side. Does this sound like the culprit? I'm going to fix it this weekend, I just want to know if a rebuilt caliper will be the end of my woes or I need to look at anything else.
Ron Paul 2008
djzero is offline   Reply With Quote
Old 11-07-2008, 11:59 AM   #2
AZ Jeff
Sounds like you are on the right track. When you replace the one caliper, do the other side at the same time to have balanced braking.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
