Brake Upgrades - JeepForum.com
post #1 of 13 Old 12-05-2007, 08:10 AM Thread Starter
rosader
rosader's Avatar
Brake Upgrades
What are my options? I looked in the tech sticky but only found a crown vic disc setup which gives you no way of reconnecting the e-brake. When I upgrade to 35's I want to have good braking. Should I upgrade the front brakes, rear, or both? I don't have a ton of cash to throw at this but I definitely want to keep this a safe DD.
'98 Jeep Cherokee Sport -Sold-
4.0L I6, auto, 4x4, dana 44 rear, AA SYE, T.W. driveshaft, Custom 5" Lift, 31x12.5 R15 Pro Comp
'02 Isuzu Rodeo Sport
3.2L V6 | automatic | hard top | 4x4
rosader is offline
post #2 of 13 Old 12-05-2007, 08:20 AM
AZ Jeff
2014 JK Wrangler
Upgrading the rear brakes on an XJ does fairly little to improve overall braking for two reasons:
1. most rear discs don't do any better than the stock drums brakes, provided the drum brakes are/were functioning as designed.
2. rear brakes only do about 25% of total braking due to weight distribution and weight transfer during forward motion braking.
If you really want to improve your brakes, you gotta focus on the FRONT brakes. It tends to get expensive, and that's why most guys avoid it.....
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 13 Old 12-05-2007, 08:36 AM
urban-yan
urban-yan's Avatar
I went all out on my brake upgrade. I bought the teraflex rear disc kit, but I also got in on a groupbuy for an Australian 300mm /slotted/ 2pistion front brake kit (I also the rotors cryo treated for longer life).
Here's my thread with some pics
http://www.jeepforum.com/forum/showt...t=brake+teaser
and here's a really nice write-up on the kit
http://www.go.jeep-xj.info/HowtoFordBAdiscs1.htm
urban-yan is offline
post #4 of 13 Old 12-05-2007, 09:03 AM
XJ_Austria
1994 XJ Cherokee
Well...always consider, you drive an off road car. With off road tires (MT's) and an off road suspension setup and no Sports Car with high performanceTires and sport suspension. You have 33's MT's which never can bring the braking performance of a sport brake system onto the road. And you do not drive with high speed and break hard for sharp cornering, do you?
So I would not spend alot of money for upgrading to a sport brake system. Okay, it may look better...but else...??
I'd rather got with a set of good quality reinforced brake lines for the front brakes and leave the rear stock. That saves you money and they really do a fine job. I've got Stahlflex onto my XJ and that really brakes very good! Of corse, reinforced brake lines cannot prevent from fading or overheating the discs, but again, I do not think you drive your XJ like a fast Porsche or BMW....
You could put in Dot4 (boiling point 230 degree) or Dot5 (boiling point 260 degree) brake fluid instead of standard Dot3 (boiling point 205 degree).
XJ_Austria is offline
post #5 of 13 Old 12-05-2007, 09:48 AM Thread Starter
rosader
rosader's Avatar
Damn urban... Can I ask where you got your lights?
As far as the comment of driving like a race car... I want good braking power for safety purposes (not squeeling around corners) I had a close call the other day when somone pulled a left right out in front of me and i had to slam on the brakes. I was not satisfied with the stopping power, and i'm running 31's... imagine what it would be like with 35's. That is why I WILL be upgrading brakes. I just need some direction so your help would be much appreciated.
edit: and I already have a quality set of front and rear extended & reinforced brake lines
rosader is offline
post #6 of 13 Old 12-05-2007, 01:32 PM
XJdamyankee
Well if you want to buy kits, Teraflex makes a rear conversion and you can still use the E-brake, they sell it at quadratec and Vanco makes a front conversion.
Front
http://www.vancopbs.com/product_p/dkj1000.htm
rear
http://www.quadratec.com/products/pr...its&c=161&pg=1
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline
post #7 of 13 Old 12-05-2007, 01:55 PM Thread Starter
rosader
rosader's Avatar
The Vanco kit looks like a good one. Would this kit work with ORO U-Turn Steering? Maybe I can call them and see.
rosader is offline
post #8 of 13 Old 12-05-2007, 02:11 PM Thread Starter
rosader
rosader's Avatar
Wow! at a second glance i noticed the 300mm kit too... Where did you get that kit urban-yan? I wonder which kit would do better???
rosader is offline
post #9 of 13 Old 12-05-2007, 02:15 PM
urban-yan
urban-yan's Avatar
My kit came from Australia, and my buddy Chris (silverXJ on jeepin.com) put together the groupbuy (otherwise, no one would buy these kits because shipping was too high on stand-alone orders)
Front
rear
front
That vanco kit looks sweet, but its definitely pricier than mine. I was able to score my 300mm kit for $530+shipping; that also included these extras: slotted rotors, ss brakelines, and powder-coated calipers. I will say, that unlike my kit, this one appears to include the custom knuckles which would make installation much quicker.
rear
www.dc4wd.com is almost $100 cheaper on that teraflex kit. quadratec wants $544. I paid $437shipped to Canada.
I will say one last thing however; Since these kits are expensive, I suggest you cryo treat your rotors to extend their lifespan. It's definitely a good investment. My F+R kits were installed the same day. Whereas my front cryo treat rotors look as good as new, my rear teraflex rotors show signs of age, and the hats are rusted.
The Bi-Xenon projectors came from suvlights.com The ballasts/D1S bulbs came straight out of a Cadillac SRX.
Last edited by urban-yan; 12-05-2007 at 02:35 PM. Reason: quoted wrong price on my teraflex kit
post #10 of 13 Old 12-05-2007, 05:31 PM Thread Starter
rosader
rosader's Avatar
The teraflex kit is not available for the D44. I will probably just upgrade the fronts.
I found this on ebay, is this a decent price? http://cgi.ebay.com/ws/eBayISAPI.dll...link:middle:us
edit: my bad, it's in australia... It looks like the vanco kit wins.
rosader is offline
post #11 of 13 Old 12-05-2007, 05:49 PM
severous01
severous01's Avatar
the 300mm kit is available on ebay for a high $$$ tag. i'd suggest some good, high quality rotors and some hawk HPS pads. and in the rear, i'd suggest discs. they're easier, self cleaning, you dont have to clean them every time you go mud, and they're easier to replace......not to mention, way less moving parts. plus the zj disc conversion is cheap, easy, and uses factory parts.
for the fronts, i really dont think anything out there is feasibly cheap. you're going to spend a grand on just the fronts...for about 125 bucks, try the stock setup with good parts.....hawks, EBC, or other 'high performance' pads. you'd be surprised what a good set of non-generic pads can do for ya.
severous01 is offline
post #12 of 13 Old 12-06-2007, 01:52 AM
urban-yan
urban-yan's Avatar
That's the groupbuy kit; we paid $530 (with free powdercoating, and considerably lower shipping)
Second, I know some people modified the teraflex kit to fit a d44, but I can't recall where I read about the retro (I'm sure one of the mods can chime in with more details)
post #13 of 13 Old 12-06-2007, 04:44 AM
96JXJ
Why can't you hook up the E-brake? Shouldn't be much different than an 8.8 or any other disc swap. You will need longer cables, but that's about it. JIM.
96@6 & 92@3
96JXJ is offline
Brake upgrades? jbarr2000 XJ/MJ Cherokee Non-Technical Forum 7 10-29-2009 10:44 AM
brake upgrades Bobandbeans XJ Cherokee Technical Forum 6 08-25-2008 04:54 AM
looking for 94 xj brake upgrades murrayII XJ Cherokee Technical Forum 5 08-12-2008 12:33 PM
brake upgrades Rowingfish87 XJ Cherokee Technical Forum 14 03-28-2008 09:29 PM
brake upgrades? Mtxz453 XJ Cherokee Technical Forum 2 07-09-2006 06:19 PM
