Quantcast Brake rotor size - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Brake rotor size
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 07-15-2005, 03:47 PM   #1
jojo6714
Brake rotor size
I went to get Front brake rotors today. The guy asked me at the parts counter what size do I have? I am not sure what he is talking about. They had 2 sizes, I think he said a 9" and a 10" I hope I have the 9", because thats what I bought. The others were about 50 dollars more. Any Ideas?
97 XJ 4.0 Sport
K&N Cone filter / Stock air tube
Cat back, FlowMaster Super 40
2.75+" BB Lift
30x9.50x15 MT
Twisted Headlight Harness
[SIZE=3][COLOR=DarkGreen]Green Jeep Club Member #161[/COLOR][/SIZE]
[COLOR=Navy][SIZE=3][B]NAVY Jeep Club #22[/B][/SIZE][/COLOR]
jojo6714 is offline   Reply With Quote
Old 07-15-2005, 04:01 PM   #2
FleXJ the Kid
Measure your old rotors. its actually easier than typing a thread. 10 inch rotors
'88 Cherokee Pioneer
Rebuilt 4.0 litre (bored .030 over)
Homemade cold-air K&N cone filter
Empty cat, Flowmaster
Rubicon Express 4.5" with leaves
BA-10 Tranny/NP 231 TC
Non-Disconnect Dana 30, Dana 44 regeared to 4.10
33x12.5 BFG MT's on Black Rock Krawler rims (3.75" BS)
FleXJ the Kid is offline   Reply With Quote
Old 07-15-2005, 06:39 PM   #3
jojo6714
hard to measure my old rotors , they are still on the jeep. Wow I wish I would have thought of that first. Anyone else?
97 XJ 4.0 Sport
2.75+" BB Lift
30x9.50x15 MT
Old 07-15-2005, 08:16 PM   #4
tangofox007
Somebody got their wires crossed here. The front rotors are 11 inches. The rear drums can be either 9 or 10 inches.
www.rockauto.com has rotors.
tangofox007 is offline   Reply With Quote
Old 07-16-2005, 07:33 PM   #5
4SEVEN3
I just bought some Brembo replacement rotors from Tire Rack. $35 ea.
I wouldnt mess with $10 rotors........thinner and not made as well. Dont mess with the safety of brakes!
4SEVEN3 is offline   Reply With Quote
Old 07-17-2005, 04:06 AM   #6
greenbeater
1968 FSJ Wagoneer
i agree the fronts SHOULD be the same as any other and the rears usualy have a couple sizes but there are always the exeptions
clicky lefty for specs and here for cardomain
http://www.cardomain.com/ride/2212742/1
greenbeater is offline   Reply With Quote
Old 07-18-2005, 07:11 PM   #7
jojo6714
When I went in to get my rotors they asked what size front rotors I had. At that point I didn't know. So i bought them, got home and did my brakes. Turns out they were the right size.
-Now I have a new problem. When I was putting everthink back together the lower bolt on the passenger side striped out the threads on the hub assy. I think I am going to put in a heli-coil, or a rosean on it, I hope it works. This happen to anyone else? How did you fixe it?
97 XJ 4.0 Sport
2.75+" BB Lift
30x9.50x15 MT
Old 07-19-2005, 02:35 AM   #8
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
Let me tell you what I went through. I keep either losing bolts, or breaking bolts. Yes I torqued to spec, and yes I tried lock tite. Indeed up stripping threads, and drill a little off one time for the easy out. Got pissed, so here is what I did. I went to Attwoods and got some either 7/16 or 3/8 grade 8# bolts. I don't remember which size. Then I drilled the holes in the outer knuckle and tapped for the larger bolts. Had to drill the sleeves for the caliper a little also. I bought the bolts to long, so I cut a little, about 1/2", off and ground the tip. Installed much larger stronger bolts, and havn't had any problems since.
Plus the Attwoods grade 8# have a shinny blue anadizoed coating.
piks
I bring NOTHING to the table.
firefighter1c57 is offline   Reply With Quote
Old 07-19-2005, 10:11 AM   #9
jojo6714
Yeah this is turning into a PITA. I have a plan, just need to get the time to do it. I have a 5/16 grade 8 bolt, I am going to helicoil it. Just a lot of work, and not enought time this week.
97 XJ 4.0 Sport
2.75+" BB Lift
30x9.50x15 MT
Glock Forum
