Brake Pedal triggers interior lights and running lights HELP!! - JeepForum.com
post #1 of 8 Old 03-14-2005, 10:07 AM Thread Starter
MontyTJ02
Okay heres the deal. Saturday nite I pull into my driveway and as Im rolling forward with the clutch in I shut my Jeep off and shut off the headlights. As I hit the brakes the dash lights and the running lights turn on and off with the brake pedal. I could tell the parking lights were on cuz I could see them in the snowbank at the end of my driveway. This has never happened before and I have no idea what triggered it. Could be a short somewhere but why do they do that with the brake pedal. WIERD!? Any one with any type of idea please help me.
BTW I have wired driving lights and my stereo and all my Fire lights but I never tapped into any stock wiring. I ran all my own for those accessories.
FireFighter's Jeep Club #84
I started out with nothing and still have most of it left.
Im getting tired of thinking...guess I'll do some wishful drinking.
MontyTJ02 is offline
post #2 of 8 Old 03-14-2005, 10:50 AM
t bell
I don't know but when you find out let me know because that sounds like a good prank.
t bell is offline
post #3 of 8 Old 03-20-2005, 04:23 PM
creeperjeep
sounds like a short between the brake light power and the running light power....mabey a pinched harness, something else...wherever it is its shorting between those 2 wires
-matt
creeperjeep is offline
post #4 of 8 Old 03-20-2005, 04:51 PM
DAT
Check the brake lamp bulbs filaments. One filament is for park the other is for brake. Make sure they are not touching each other. Also check the contacts on the bottom of the bulbs for damage. Check the sockets also. Good luck and let us know the fix.
DAT is offline
post #5 of 8 Old 03-20-2005, 08:25 PM
BrunoS
Been there, done that. DAT is right:
Pull both rear lamp housings off tailgate area (3/8 socket, methinks)
Pull ALL plugs out and iNSPECT. Replace any blown ones in pairs (both L and R side)
You have a shorted out brake lamp. it feeds back to the brake switch after you have been driving with the lights on at night, etc. after a while, pressing brake pedal when lights are turned off and it won't happended.
Do a search of my name BrunoS and brake lights and you'll find the write up.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #6 of 8 Old 03-21-2005, 10:31 AM Thread Starter
MontyTJ02
Thanx guys...I figured that same thing out this weekend. The driverside and passenger side bulbs were both touching the other filament. Thanx for your help tho. It took me 3 hours to figure that out. thanx.
post #7 of 8 Old 03-09-2012, 08:06 AM
mamkaca
thanks a lot i have the same problem now i can go directly to the problem
mamkaca is offline
post #8 of 8 Old 01-11-2017, 02:24 PM
LewisWetzel
I'd like to reopen this thread please
I have the same issue on a 2000 XJ- I removed both rear bulbs, and with the pedal applied, the front running lights still come on. any ideas?
LewisWetzel is offline
Brake lights work...but NOT with the brake pedal (???) aallppiinnee XJ Cherokee Technical Forum 4 03-08-2009 06:26 PM
Brake light works but not running lights Fenris XJ Cherokee Technical Forum 4 12-27-2008 01:28 PM
1990 XJ No tail lights Running lights) and no dash lights Pistolspark XJ Cherokee Technical Forum 2 08-19-2008 07:29 AM
Tail lights, interior lights, brake lights... no work 4x4life XJ Cherokee Technical Forum 11 02-15-2006 10:28 PM
Brake lights on / pedal hard jabco XJ Cherokee Technical Forum 8 06-12-2005 11:49 AM
