Brake line hanging? - JeepForum.com
post #1 of 6 Old 02-13-2013, 07:55 AM Thread Starter
nygiants
Brake line hanging?
Went wheeling over the weekend and even though I was following a bronco on 35" m/ts there was a fair amount of thick ice in puddles that he broke up. now I had all new brake lines put in at the end of summer I'm not sure if my brake lines supposed to be hanging like this the other side isn't if it is how could I fix it
nygiants is offline
post #2 of 6 Old 02-13-2013, 02:32 PM
critmuncy99
E Brake...All XJ's Ive Seen Hangs In That Same Location...
(J-E-E-P) Chew Them Up And Spit Them Out The Other End (J-E-E-P)
critmuncy99 is offline
post #3 of 6 Old 02-13-2013, 03:28 PM
sAe23
1995 XJ Cherokee
You are missing the retainer spring...
Here's a pic of mine. The driver side spring is at the top, and the passenger side cable can be seen in the background:
sAe23 is offline
post #4 of 6 Old 02-13-2013, 03:29 PM
sAe23
1995 XJ Cherokee
Unless this is yet another one of those differences between 95 and new models
sAe23 is offline
post #5 of 6 Old 02-13-2013, 03:58 PM Thread Starter
nygiants
Well mines a 99 Its certainly possible I ripped off the retainer spring in the ice
nygiants is offline
post #6 of 6 Old 02-13-2013, 05:23 PM
MJR
MJR's Avatar
1988
97-up are a bit different. You should be able to pull the shock off the bottom mount and run it over the top of the tube.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
