brake lights will not work - JeepForum.com
post #1 of 13 Old 01-06-2012, 02:47 PM Thread Starter
silentdebo
1993 XJ Cherokee
I have a 1993 jeep cherokee and the brake lights stopped working on me when I was on a trip from CA to AZ. The running lights still work, just not the brake lights. I have checked fuses, light bulbs and even hooked up my uncles circuit tester to see what was going on and we were getting no signal on brake lights but getting a positive on the running. I have no idea what the issue is and co-worker recommended I check here before I take it into a shop. Nothing worse then paying $200 for something could have cost $20.
silentdebo is offline
post #2 of 13 Old 01-06-2012, 03:25 PM
mj40
1989 MJ Comanche
check the firewall block to the fuse box..green death got to this 92....your signals and brakes are supplied by one wire as well the 4way/hazards...park is fed from another supply..
to fix my buddys 92 i just drilled out the contact pins and fed a new wire through the hole, you could silicone it to seal...spliced it into the original wires..
mj40 is offline
post #3 of 13 Old 01-07-2012, 02:28 PM Thread Starter
silentdebo
1993 XJ Cherokee
thanks a ton man that helped me out so much.
post #4 of 13 Old 02-11-2013, 04:55 PM
zjroughrider
i am having the same issue and will check this out.
thanks man ill post my findings
zjroughrider is offline
post #5 of 13 Old 02-12-2013, 04:25 PM
JWELK
If your turn signals and brake lights are the same bulb (American Style), the brake lights go through the hazard switch. Try activating it a couple of times, that usually solves the issue.
Regards,
Jim W
JWELK is offline
post #6 of 13 Old 02-12-2013, 04:59 PM
MJR
MJR's Avatar
1988
Ah brake switch above your feet maybe? Jumper power from the 16PK/BK (fused +12V) to the 18WT/TN (brake light bulbs) and see if they work.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #7 of 13 Old 02-15-2013, 10:37 AM
zjroughrider
Still trying to figure this out. Brake light switch has no power. No power at rear lights as well. I have power at the fuses. The hazards also don't work and the turns stoped working. I wonder if my problem lies in the turn signal switch
post #8 of 13 Old 02-15-2013, 10:38 AM
zjroughrider
Also noticed that the powers seats don't work and neither does the horn.
post #9 of 13 Old 02-15-2013, 11:23 AM
MJR
MJR's Avatar
1988
Well on a Cherokee the brake lights don't go through the turn switch. I'm thinking the bulkhead connector/fuse box as suggested by mj40 above is most likely where your problem is. I've seen water get in it and corrode away the terminals.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #10 of 13 Old 02-15-2013, 02:35 PM
zjroughrider
I removed the power relay centre and everything looked good and had power. I'm trying to trace wires from the in car fuse panel. The brake light fuse has no power.
post #11 of 13 Old 02-15-2013, 03:18 PM
zjroughrider
fuses # 1,2,3,4,5,6,7,14,23,24 and 28 dont have power. This is really staring to stump me.
post #12 of 13 Old 02-15-2013, 03:18 PM
zjroughrider
sorry 5 has power
post #13 of 13 Old 02-15-2013, 04:16 PM
MJR
MJR's Avatar
1988
The bulkhead connector is right behind the under dash fuse box. Two screws hold it to the firewall and one bolt holds the underhood part to the under dash part.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
brake lights , electrical , not working
How does this work ? RedMountainRob JeepForum Announcements 3 05-07-2011 05:33 AM
Does Search Work? Keith JeepForum Announcements 11 06-03-2008 07:04 AM
How do I get avatars to work cosninocanines JeepForum Announcements 7 04-05-2008 07:24 PM
Does the Live Chat work? Jeepgofast JeepForum Announcements 2 10-19-2004 06:47 PM
Can't get my account to work!!!! Scratchnbell JeepForum Announcements 3 07-18-2003 06:18 PM
