Brake Issues on 1990 Cherokee - JeepForum.com
post #1 of 5 Old 04-06-2013, 12:16 PM Thread Starter
tgoad
1990 XJ Cherokee
So I just got done bleeding my brakes and there was no change in my braking. I still have to put the pedal all the way to the floor and even then I'm hardly braking. The pads are not that old only like 4 months or so. When I press the pedal I can hear hissing from it. I haven't had to add fluid so its not leaking out. If anyone has any thoughts of what might be going on, I would love to hear them.
tgoad is offline
post #2 of 5 Old 04-06-2013, 12:34 PM
Timo_90xj
Timo_90xj's Avatar
First things first, do you have on XJ, or a full size like you claim on your info (and btw., the 4.0 is not a V6..)? Second, ABS or standard brakes?
If you have standard brakes and the pedal goes all the way to to floor, you most likely have a bad master cylinder. Booster may hiss a little during braking, but if it's bad you'd have a very hard brake pedal. Air in the system and you've got a spongy feel on the pedal, bad MC makes the pedal go slowly all the way to the floor (and you have reduced or no braking power).
***Under construction***
Timo_90xj is offline
post #3 of 5 Old 04-06-2013, 12:48 PM Thread Starter
tgoad
1990 XJ Cherokee
its four door so yeah full size, and standard. The brakes feel spongy but i just bled them and they're still spongy
tgoad is offline
post #4 of 5 Old 04-06-2013, 01:31 PM
79chiefs
1988 XJ Cherokee
NO no a FSJ, and XJ are two different types of jeeps. Google it for clarification. They did not make a FSJ Cherokee in 90, but did make a FSJ Wagoneer in 90. Did you bleed them through the line fitting or bleed screw?
Edit---You hear air, then it may be a bad Master Cylinder.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #5 of 5 Old 04-07-2013, 07:00 PM Thread Starter
tgoad
1990 XJ Cherokee
sorry misunderstood, i have a XJ. Bleed them through the bleed screw. Im thinking the Cylinders bad
tgoad is offline
brakes , cherokee
