Brake issue '94 GC 5.2 - JeepForum.com
post #1 of 2 Old 10-02-2009, 06:15 PM Thread Starter
FALudwig
1994 ZJ
When off, the brake pedal is firm. When you start the engine, the pedal travels right down to the floor with a slight whoosh sound. Fluid level is good, no leaks seen. Would this be a booster or MC problem?
Thanks.
FALudwig is offline
post #2 of 2 Old 10-02-2009, 06:18 PM
USMC_XJ
2003 WJ
Wrong section, but I would try bleeding the master cylinder. Usually if the pedal is firm with the engine off, the booster is fine. However, it might be the other way around.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
front brake issue 98CherokeeLTD XJ Cherokee Technical Forum 7 06-28-2009 12:25 PM
bleeding brake issue phmaris XJ Cherokee Technical Forum 1 05-03-2009 04:38 PM
Weird Brake Issue! epix XJ Cherokee Technical Forum 1 10-27-2008 09:57 AM
Another brake issue meiguy XJ Cherokee Technical Forum 3 06-26-2006 07:45 AM
Brake issue teqmod XJ Cherokee Technical Forum 0 04-23-2006 12:41 PM
