Brake Issue in 87' XJ... - JeepForum.com
post #1 of 3 Old 09-20-2011, 12:20 PM Thread Starter
FleshEater
2014 JK Wrangler
I'm having a weird issue with my brakes...if this sounds familiar and can be pinpointed I'll be super happy!
The issue is as follows; I have no brakes, when I pump up the pedal I have no pedal and when I hold the pedal down it doesn't go to the floor...it just stops about 2-4 inches from the floor. It's almost like it just keeps hitting a wall and not building any pressure. I was going to look for a leak but if it's not going to the floor I don't have much to go on.
Anybody think this could be the brake power booster/master cylinder going bad or could it be a vacuum issue? I've never had this issue before...they've always just gone to floor.
Thank you for any input.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #2 of 3 Old 09-20-2011, 08:17 PM
AZ Jeff
2014 JK Wrangler
Booster/vacuum issues have no effect on basic braking, other than making pedal pressures for a given brake force lower.
Since you have NO brakes, you can dismiss them as an issue.
Let's start with the basics---is the master cylinder full of GOOD brake fluid? Have you tried to BLEED any of the brakes, and if so, do they bleed normally?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 3 Old 09-20-2011, 08:25 PM Thread Starter
FleshEater
2014 JK Wrangler
Ok, so tonight I was messing around with them with my dad. I found the electrical connection for the brake sensor removed and we pushed the black rubber button (or whatever it is) on the end of the brake lines...now I have brakes. The brakes still need bled but I guess that black button is a reset button or something? I don't know...but it worked.
Brake issue (89 Cherokee) Meangunz XJ Cherokee Technical Forum 15 12-12-2010 10:57 PM
Bit of an issue after brake job. leadnbrass XJ Cherokee Technical Forum 7 05-07-2010 01:24 AM
Brake issue '94 GC 5.2 FALudwig XJ Cherokee Technical Forum 1 10-02-2009 07:18 PM
Another brake issue meiguy XJ Cherokee Technical Forum 3 06-26-2006 08:45 AM
Brake issue teqmod XJ Cherokee Technical Forum 0 04-23-2006 01:41 PM
