-   -   brake issue (http://www.jeepforum.com/forum/f11/brake-issue-1322540/)
ISAACAH 01-31-2012 11:23 PM
brake issue
Hey I have an issues with my 89 Cherokee itís not abs I replaced the master cylinder, rotors, calipers, and drums. I and someone else bled the system correctly no air. But it wouldnít stop unless I put it to the floor, so then we extended the pin that pushes the piston. It stopped better and if I put the brake to the floor the rears would lock but when I push on the breaks it feels empty. they stop but thatís not my issue, my issues is I was driving it home and the brakes started to lock up I could drive but couldnít go over 25. I didnít even have to press the brake to stop and when I did the pedal would be all the way at the top and I could press down as if they were already to the floor no more movement. I get home the front brakes are extremely hot so I let them cool off then I get back in after 2 hours or so and they are back to normal. So Iím just asking would it be because the pin I extended out it wonít let the brakes bleed out?, Or any other issues
AZ Jeff 02-01-2012 10:09 AM
You should NEVER extend the pushrod beyond the recommended distance listed in the FSM. I don't know what that distance is for your model, but perhaps someone with the older single-diaphram booster can chime in.
ISAACAH 02-01-2012 11:10 AM
http://www.jeepforum.com/forum/f11/b...ng-rod-291344/
seems like this guy had the same issue i might have loosen it out too much i guys ill have to pull it back in a Little more.
The time now is 03:50 AM.
