brake caliper knuckle problems need help - JeepForum.com
post #1 of 4 Old 08-15-2005, 05:38 PM Thread Starter
AzAuto
hey, one of my brake caliper bolts broke in the knuckle that holds it after trying to drill out and retap i realized that it cant fit any bigger bolts or anything so i need a new knuckle or any idea on how to fix it anyone know where to get a knuckle for cheap or have one?
1999
4.0L Power Tech I-6 Engine
4-Speed Automatic AW4 Transmission
231New Process Command-Trac Part Time 4WD System
Dana M30/181MM Front Axle
3.55 Axle Ratio
Corporate 8.25 Rear Axle
30X9.50 Mastercraft MT
"cherokee making the impossible possible since 84"
Originally Posted by Bolognablake
I love my lifted Jeep because it's really easy to change the oil.
AzAuto is offline
post #2 of 4 Old 08-15-2005, 06:32 PM
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
yes you can fight a larger bolt. I am currently running 4 7/16 bolts in my front brakes. Take the metal sleeve out of the caliper, the part with the rubber boot on it. Take the boot off, and drill the sleeve out to accept the larger bolt. IIRC I used two inch bolts, but I actually trimmed them down a little with the bench grinder to keep them out of the back of the rotor.
I bring NOTHING to the table.
firefighter1c57 is offline
post #3 of 4 Old 08-15-2005, 08:12 PM
XJohnnyC
XJohnnyC's Avatar
I just repaired a stripped out caliper bolt hole this weekend using a Perma-coil kit. The caliper bolt is M8x1.25. The instructions said to drill the hole out to 21/64, tap the hole with the supplied tap, then install one of the inserts. Worked great and was super easy too.
So if the hole is no bigger than 21/64, you can use the Perma-coil kit. If the hole is already bigger than 21/64, you can get the next biggest kit, which I believe is M9x1.25, and get a new bolt. But you'd have to do as cruzmyxj said and drill out the sleeves.
XJohnnyC is offline
post #4 of 4 Old 08-18-2005, 08:34 PM
artboy
artboy's Avatar
Been there done that many moons ago with a heli-coil kit... worked great...saved my a$$!
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231
1996 XJ Sport Daily Driver - 190k, stone white, 4.0, automatic, selec-trac NP242.
2005 Wrangler Rubicon Summer Toy - 26k, 100% STOCK...silver, automatic, soft and hard tops and doors
"life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller
artboy is offline
caliper bolts sheared off in 98 xj, pieces stuck in steering knuckle compcrasher86 XJ Cherokee Technical Forum 2 01-23-2010 09:34 AM
Caliper shimmy, stripped knuckle? mtl4life XJ Cherokee Technical Forum 27 05-30-2008 08:09 AM
Steering Knuckle/Brake Problem again!! shaddady34 XJ Cherokee Technical Forum 3 04-11-2008 08:28 PM
brake caliper Rzup96 XJ Cherokee Technical Forum 6 06-19-2007 09:55 AM
brake caliper 91xjgawes XJ Cherokee Technical Forum 5 08-18-2006 06:31 PM
