Brake Booster Problems - JeepForum.com
post #1 of 4 Old 07-18-2011, 09:10 PM Thread Starter
Caleb9107
1990 XJ Cherokee
Hi all,
I have an '88 XJ and I am currently having brake problems that I believe are centered around my booster. When I bought the jeep, the brakes were very soft. I immediately replaced pads/rotors and shoes and installed a new MC. The problem then was the leaking vacuum sound coming from the booster. To remedy this I installed a booster from a '91 parts XJ I have. With this booster installed, the pedal continued to go to the floor and hiss (making the leaking vacuum sound) and would gradually stop the Jeep. Today, I pulled the booster from a '90 in the local pick-n-pull yard. Now my problem is that I have a very VERY stiff pedal, and a very loud hiss from the time the pedal begins to depress. To give you a reference of how hard the pedal is to depress, I am 6'3" and have my seat back all the way and have to brace myself against the seat to actually get the pedal depressed 1-2".
Summary:
New MC, pads, rotors, shoes.
Original booster: vacuum leak, pedal to the floor.
Second booster: vacuum leak, pedal to the floor.
Third booster: VERY loud vacuum leak, impossibly stiff break pedal.
Has anyone out there had similar problems to this? I have looked at this thing numerous times and there I can't see any possible way that I could have installed this incorrectly, but I am open to any advice you are willing to send my way!
Thanks,
Caleb
Caleb9107 is offline
post #2 of 4 Old 07-19-2011, 11:17 AM Thread Starter
Caleb9107
1990 XJ Cherokee
Further information:
All these symptoms are with the engine running. With the engine off, the pedal has good resistance. I removed the line from the booster and the vacuum is very sufficient coming from the engine. Is this indicative of a bad booster or could I have some further problem?
post #3 of 4 Old 07-19-2011, 12:25 PM
seu83
It sounds like the last booster you put on that gave you the stiff pedal is the only one thats bad.
Did you check you lines? It sounds like you may have a slow leak somewhere.
seu83 is offline
post #4 of 4 Old 07-19-2011, 01:24 PM Thread Starter
Caleb9107
1990 XJ Cherokee
Thanks for your input. The problem I have in wrapping my mind around the other two being good boosters was that when fully depressed, I could hear the vacuum sound coming from the INSIDE of the cab. I am trying to find out if there are any ways to disassemble the booster to test and see if any of the parts inside are replaceable or determine how to localize my problem!
ZJ brake booster on XJ? jeepster89 XJ Cherokee Technical Forum 9 08-09-2012 01:59 AM
Changed brake booster now brake lights stay on Spooledbseries XJ Cherokee Technical Forum 2 09-30-2010 12:30 AM
93 cherokee - wj booster/8.8 brake problems sumofatguy XJ Cherokee Technical Forum 6 10-19-2009 11:43 AM
brake pedal very soft after dual diaphragm brake booster upgrade 180XJ92 XJ Cherokee Technical Forum 1 09-14-2009 02:06 AM
Brake Problems on 87-Brake Booster? tyytyy22 XJ Cherokee Technical Forum 2 01-30-2006 12:36 PM
