Brake Booster, Or do I need to Bleed the Brakes? - JeepForum.com
post #1 of 3 Old 03-10-2010, 06:32 PM Thread Starter
gmgunicycle
1989 XJ Cherokee
What's up everybody...My 1989 Cherokee Limited is having a braking fit. The pedal is traveling all the way to the floor, making it impossible to drive it anywhere. I read my Haynes manual for the truck and it says that It could be one of two things. Either air in the brake lines, or a bad power brake booster. Any suggestions?
Thanks,
G
gmgunicycle is offline
post #2 of 3 Old 03-10-2010, 07:24 PM
AZ Jeff
2014 JK Wrangler
Its NOT the power booster. Its a hydraulic leak, probably in the MC, if the reservoir is full.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 3 Old 03-11-2010, 08:37 AM Thread Starter
gmgunicycle
1989 XJ Cherokee
AZ,
Thanks for the tip. The M C is full, not leaking any fluid. So I should go about checking the lines that are connected to the M C, or do you think a NEW M C would be the way to go.
G
Air in Brakes Cannot Bleed it Out dug320 XJ Cherokee Technical Forum 13 12-29-2009 10:40 AM
Soft brakes even after manual bleed wernettejr XJ Cherokee Technical Forum 2 11-07-2009 04:21 PM
Will I need to bleed the brakes? Vi-Queens XJ Cherokee Technical Forum 9 05-02-2009 08:50 PM
88 Mj brakes wont bleed dcollin10 MJ Comanche Technical Forum 3 09-29-2008 01:50 AM
How do you the Bleed Rear Brakes ? 01JeepXJ XJ Cherokee Technical Forum 4 11-27-2005 11:59 PM
