brake boost on hydro drive abs brake system - JeepForum.com
post #1 of 11 Old 02-15-2013, 11:37 AM Thread Starter
old_beater
I lost my power assist on my braking system. it's on a 90 cherokee laredo with abs I was told it would probably be the hydro pump that went bad but that part is listed at 500+, is there any other (cheaper) parts that could cause this same problem?
old_beater is offline
post #2 of 11 Old 02-15-2013, 11:44 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
That system is prone to failure. You're
better off ditching the ABS for a conventional booster/master cylinder set up
1990JEEPXJ is offline
post #3 of 11 Old 02-15-2013, 11:51 AM Thread Starter
old_beater
how do I switch out over?
post #4 of 11 Old 02-15-2013, 12:04 PM
AZ Jeff
2014 JK Wrangler
If you use the search function for "removing 1990 ABS" or similar, you will find lots of info on this, but the summary is as follows:
1. Acquire vacuum power booster, master cylinder, and proportioning valve for 1995-1996 model.
2. Remove your existing pump, accumulator, and distribution system. Save all hard lines for possible reuse.
3 Install parts from step one.
4. Fabricate hard lines to connect various ports and install same
5. Bleed system.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 11 Old 02-15-2013, 12:16 PM Thread Starter
old_beater
ok where does the vacuum line come from for the booster.
post #6 of 11 Old 02-15-2013, 12:44 PM
buildin1XJ
From the intake manifold.
buildin1XJ is offline
post #7 of 11 Old 02-15-2013, 01:11 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Yes. There is a plug on the manifold. Remove it and out in the appropriate nipple. You can also use the booster and master from a WJ. same performance and work to install. Just fits a little better with regards to the washer bottle.
post #8 of 11 Old 02-15-2013, 01:25 PM Thread Starter
old_beater
they list 90's with conventional boosters should I get that or the setup from a 95-96
post #9 of 11 Old 02-15-2013, 02:39 PM
kstopp
1993 XJ Cherokee
90's up to 94 have a single diaphragm booster. 95-96 have double diaphragm booster as do the WJs from 99-04.
Double diaphragm means more braking power, I would suggest you go that route.
kstopp is offline
post #10 of 11 Old 02-15-2013, 02:54 PM Thread Starter
old_beater
cool thanks guys thats the route I'm headed
post #11 of 11 Old 03-01-2013, 06:49 PM Thread Starter
old_beater
alright the conversion to a vacuum booster is done! everything works great it was just rough getting it all bled
