Bouncy ride - JeepForum.com
post #1 of 12 Old 10-10-2012, 05:49 AM Thread Starter
nyyankee
Bouncy ride
My 2000 sport feels clangy and jumpy over bumps. I just had the shocks replaced and sway bar link and u joint axle. What else should I be looking for.?
nyyankee is offline
post #2 of 12 Old 10-10-2012, 08:07 AM
GetLifted
Upper and lower control arm bushings, tie rod ends, upper and lower ball joints.
GetLifted is offline
post #3 of 12 Old 10-10-2012, 08:13 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Is this new since the shocks were installed ?
Is the Jeep stock or modified ?
What tire pressure are you running ?
CJ7-Tim is offline
post #4 of 12 Old 10-11-2012, 06:41 AM Thread Starter
nyyankee
Its all stock and it always was like that. Sounds like an old oil can when hitting bumps at low speeds and windows closed so you can hear links. Must be a bushing or something. It's not awful but it's not smooth either. Just put new tires on yesterday so pressure is normal. Truck has 90k on the ticker but the car sat since new and was only used on snowy commute days and everything underneath is rusted. Not rusted through but rusted. They had to re-drill the shocks.
nyyankee is offline
post #5 of 12 Old 10-11-2012, 10:27 AM
VBRubicon
VBRubicon's Avatar
"Normal" tire pressure for cars isn't the same as jeeps.... Check it/drop it to 25 - 30 lbs. Anything over 30 and it's going to ride terrible terrible. Which most shops will naturally do....
If you can stick the cam under the jeep and snap a couple more pics, you'll get a lot more info and advise. Focus on the shocks if you can also because if the shop moved the mounts one way or the other, they may be bottoming or topping out. Which you would undoubtedly feel...
If the shock mounts were rusted through that bad, your clunking could really be anything at all. I, or anyone else for that matter, would probably give you this list to start: u-joints, exhaust, trans/crossmember mount, sway bar links, shock mounts(even though shop said they fixed), wheel bearings, or ball joints.
Really a guessing game without more info and/or pics...
-What does the jeep do when you bounce it up and down front and rear(check both)? Does it keep bouncing for a while? Any odd noises?
-Where does the clunking sound like it's coming from? Front/rear/directly under you?
-Is the noise effected by any driving conditions at all? Accel/decel, braking, turning one way or the other? Does it pop/clunk when you put it in gear?
-How's the handeling/steering? Seem to sway one way or the other? Steering feel loose or sloppy at all? Pull to either side?
Errrr.....ever get the feeling you've had too many Jeeps for waaaaay too long...
"Yeah well, that's just like...your opinion, man."
-El Duderino-
Mr. Madison, what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
VBRubicon is offline
post #6 of 12 Old 10-11-2012, 10:58 AM Thread Starter
nyyankee
Shocks are 1 week old. The sound comes from front but adible only in the truck. Handling/Steering fine, Bounce is great. Steering a little loose but Im coing from Mustangs .
nyyankee is offline
post #7 of 12 Old 10-11-2012, 11:32 AM
VBRubicon
VBRubicon's Avatar
Can you take anymore pics? Like the 3rd one you posted...only with the tire turned all the way to the left and facing towards the front a bit more....sounds like sway bar link bushings a bit. I'll show you what your looking for when I get home to my currently incapacitated Cherokee. Ha!
If you do take more pics, one directly from the front as low as you can get the cam facing up a little at the front axle housingish...
Can you describe the sound any better? Single pop, grind, clunk....??
-El Duderino-
post #8 of 12 Old 10-11-2012, 11:50 AM Thread Starter
nyyankee
Ill go do that now. It sounds "jiggly" no popping when you hit the bumps the car kinda jumps.
nyyankee is offline
post #9 of 12 Old 10-11-2012, 12:02 PM Thread Starter
nyyankee
Rusty huh? And this car only has 90k
nyyankee is offline
post #10 of 12 Old 10-11-2012, 06:06 PM
CJ7-Tim
CJ7-Tim's Avatar
What brand of shocks ?
What tire pressure ?
It is a 4x4 truck, and will never ride like a car.
CJ7-Tim is offline
post #11 of 12 Old 10-12-2012, 06:09 AM Thread Starter
nyyankee
Im not trying to make it drive like a car. This is my 4th Sport and I have a 2010 Sahara so I know how they drive. I'll get it checked out. Thanks for your help.
nyyankee is offline
post #12 of 12 Old 10-13-2012, 09:32 PM
RestoringDadsCJ
1946 CJ2A
Noise
Make sure your track bar mounting bolts , and your track bar nut is good and tight, my 96 country was getting a sharp pop when turning sometimes and over things like speed bumps or pot holes, I searched for months till one day I was under it and my buddy moved the steering wheel as he sat down for a bit and I seen it move as it popped. I took it apart bought new grade 8 bolts for the mount, applied a little locktite on the bolts,a nd torqued them down really good, poppin noise all gone. Also all that rust would make me nervous if that was my rig, might wanna get a good hard bristle sanding disc and clean and inspect everything really well, never know where a there could be a problem just hiding.
RestoringDadsCJ is offline
